Need Help with new Tacoma lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by motomatt524, Aug 19, 2015.
  1. Aug 19, 2015 at 11:03 AM
    motomatt524
    motomatt524 [OP] Member
    2015 silver tacoma TRD sport
    I just bought a new 15 tacoma DCSB 4x4. I am curious if i can run 285/70/17 tires on bilsteins 5100 in the front set at 2.5 with stock coils? I am going to buy aftermarket 17's with the correct backspacing but i would like to know if that set up will work to fit those tires and save some $$$ . And also if i leave the rear stock will that look ok or will i need a AAL. If anyone has pics of this set up that would be AWESOME!!!!!
    Thanks,
  2. Aug 19, 2015 at 11:47 AM
    motomatt524
    correction, I meant setting the 5100's at 1.75
  3. Aug 19, 2015 at 12:08 PM
    VandalTaco
    VandalTaco Well-Known Member
    Will
    Moscow/Idaho falls, Idaho
    07 DCSB TRD SPORT
    OME 887 lift, 16" XD addicts, 285 duratracs, leather seats, badass JL/Focal stereo
    I think at 1.75 you might be just a tad nose high, if not it may still look that way. So if you don't mind that then don't worry about the AAL. I think you will need to do quite a lot of trimming to fit 285s with that lift. I got 3" and had to trim quite a bit...
  4. Aug 19, 2015 at 12:23 PM
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    I actually had the 5100's set at 1.75" with 285/70r17's before changing my coils out as I moved up in size and had not received the coils (OME 885) yet. On road, they rubbed only when on full lock and backing up but it's doable though I did have the plastic trimmed.
  5. Aug 19, 2015 at 1:32 PM
    motomatt524
    well i appreciate the feedback guys. Looks like I might just bite the bullet and just order some OME coils and AAL
  6. Aug 19, 2015 at 1:33 PM
    VandalTaco
    Will
    07 DCSB TRD SPORT
    Get the 5100/OME bundle kit from headstrong offroad! That's what I got and I love it! Cheap too
  7. Aug 19, 2015 at 1:35 PM
    motomatt524
    Vanaltaco, how you like those 887's? I'm leaning towards those
  8. Aug 19, 2015 at 1:40 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    you will rub.... i have yet to see a 285/75R16 sized tire (or what ever the same size is in a 17in rim) fit without rubbing of some kind. Inner fender for sure... and if you actually flex your truck... pinch weld, cab mount chop and flare cutting / removal will be in your future.
    If its a mall crawler it might be a little easier, it will still rub though.
    aubi1414 likes this.
  9. Aug 19, 2015 at 1:46 PM
    aubi1414
    aubi1414 War Eagle!!
    Justin
    Pensacola, FL
    2014 Tacoma TRD Sport Blue Ribbon Metallic
    LED Dome, LED Map, LED License Plate Bulbs, , Konig SixShooters Matte Black, Toyo Open Country ATII's 285 70 17, Satoshi, Bilstein 5100s (set to 0), 885s, LR UCA's, Icon RR 2.0 +2, All Pro Standard 3" Leaf Pack, All Pro Flip Kit, Sway Bar Relocate, Exhaust Chop, Antenna X 14", Debadged, Tint, Matt123 Black TRD Skid, Black Weathertech Mats
    285 70 17 nope not with 1.75. I am sure it can be done though. I have a 3" lift and run the same size tire and had to remove the fenders, cut a ton of plastic/remove it and cut a lot of the cab mount. Still working on cutting out all of the cab mount and beating the pinch weld back.
  10. Aug 19, 2015 at 2:04 PM
    VandalTaco
    Will
    07 DCSB TRD SPORT
    I love them. Truck rides great and looks better!
