Need help with offset and tires
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gageseth419, Jan 14, 2024.
  1. Jan 14, 2024 at 10:01 PM
    gageseth419
    gageseth419 [OP] Member
    Gage
    2009 4WD Double Cab Tacoma
    I have a 2009 Tacoma with 17x9 wheels that have a -12 offset. I currently have 265 70 r17 tires on these wheels. Also I have a 3 inch front and 2 inch rear level. Eventually I want to get 16x8 wheels with 285 75 r16s. I need to know if anyone has anything similar and If I would be able to fit these without getting a higher lift. Also I’m wondering what would be the best offset to get the 16x8s in?
  2. Jan 14, 2024 at 10:46 PM
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    You will have more tire choices staying with 17's. I would just keep your current wheels and go with 285/70/17's they will be basically be the same diameter as the 285/75/16's. Lifts can be part of the equation for tire fit but there is a lot more to it. Thinking lift is the answer only sends you down the wrong path.
  3. Jan 14, 2024 at 11:23 PM
    TacoTuesday1
    SD CA
    Its often recommended to not lift above 2-3”.
    33”-35” on that lift is common.
    16 does not fit 4runner BBK
  4. Jan 15, 2024 at 12:57 AM
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
    When I ran 16x8 wheels with 285/75/16 I had a -12 offset. I believe all I needed was a cab mount chop if I remember correctly. It was a long time ago. Front was fine as I was running an aftermarket bumper. As stated above, IFS lift does not equate to more room for tires. Simply put if it rubs on stock suspension, it'll rub with a lift.
  5. Jan 15, 2024 at 1:58 AM
    6 gearT444E
    Deep South
    Herculiner Hootus
    Here have you, welcome to TW
