Need help with overhead console temp/compass install
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kevinva, Feb 1, 2009.
  1. Aug 26, 2009 at 3:01 PM
    jefferson
    jefferson needs to stop cruising Buy/Sell/Trade....
    Sex Panther
    San Diego (North Park!), CA
    05 PreRunner SR5
    toyota brand hitch and uhaul wiring harness, fog lamps on anytime, bed lamps, map lights on with dome, day time running lamps, remove secondary air filter, painted bumper grill, Double Din touch screen stereo, Sockmonkey custom SR5 decal, door & seatbelt bells disabled, painted engine cover, installed compass/temperature overhead console, failed mod: passenger side auto down window switches, weathertech front mats, RedLine hood struts, Cheap Beep piezo buzzer locking beep, 5100s in the front set at 2.5, 5100s in the rear, AAL, hitch safe, revenge fab sliders, bed bar, prerunner light, cb wired
    TRD shouldnt matter whatsoever, the wiring harnesses are all the same for prerunners, TRD off road, TRD sport, and XRunners
  2. Aug 26, 2009 at 6:14 PM
    jasper07
    jasper07 Member
    Florida
    10 V6 4WD 6 SPEED DOUBLE CAB
    I had the wiring diagram for the 09 and the ambient temperature sensor behind the grill works through the a/c amplifier. On my truck the sensor does not feed out of the amplifier to the wiring harness to the overhead console. I have a 2009 overhead console with a 2009 temp/compass cluster and it does not work. Only dashes where the temp should be. Its not the harness but the a/c amplifier. I spoke to a friend at Toyota parts dept and there are two different a/c amplifiers for a 2009 Tacoma. I don't know how he got his to work, but mine will not.
  3. Aug 26, 2009 at 7:03 PM
    kevinva
    kevinva [OP] Active Member
    Virginia
    09 Double Cab SR5 4x4 Longbed
    Does the wiring harness in your roof have five wires? According to the 09 wiring diagram, the temperature signal comes in on the yellow wire (pin 5). Do you have a yellow wire in pin 5?
  4. Oct 8, 2009 at 7:08 PM
    kevinva
    Virginia
    Just an update on my temperature/compass install in my 2009 SR5 DC:
    I was just about to spend a Saturday afternoon installing a new temperature probe and running the wires up to the 2006 temperature/compass console that I have, when I found a 2009 temperature/compass console on Ebay for $185 shipped. I had seen others selling for over $400 which was out of my price range, but this one was more reasonable. So I bought the 2009 console, plugged it in, and now I have a working temperature and compass readout.
  5. Oct 19, 2009 at 7:43 PM
    Phillyguy
    Phillyguy Member
    Philadelphia
    09 DC 4x4 SR5
    Still brand new.
    So was it a simple swap with no amp conversion?
    I have a 09 SR5 and recently thinking of doing the same thing. I know there was some concerns that there were two different set ups for Non-TRD and TRD.
  6. Oct 19, 2009 at 8:55 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    Lucky bastard. I went to the dealer awhile back and was quoted just a shade over a grand to buy one from them.
    After that, I realized $400 wasn't a bad price. Good find, I'll have to keep checking ebay with a little more consistency.
    mahaloTaco likes this.
  7. Oct 19, 2009 at 9:03 PM
    jefferson
    Sex Panther
    05 PreRunner SR5
    i got mine for 175 off of our For Sale section.
  8. Oct 19, 2009 at 9:34 PM
    dexterdog
    Oly WA
    2012 F150
    Yeah, but do you have an '09 or newer?
  9. Oct 19, 2009 at 9:54 PM
    jefferson
    Sex Panther
    05 PreRunner SR5
    I bought it in 08.
  10. Oct 19, 2009 at 10:15 PM
    kevinva
    Virginia
    Yes, for me (2009 SR5 4x4 DC LB) it was a simple swap of overhead consoles. The person who posted that he had trouble drives a 4cyl Tacoma, I would guess that is the reason a simple swap did not work.
    Check the connector in your headliner (it's plugged in to the dummy plug on your non-temperature overhead console) -- as long as it has five wires I think you should have no problem swapping in a new console.
  11. Oct 20, 2009 at 5:10 PM
    Phillyguy
    Phillyguy Member
    Philadelphia
    09 DC 4x4 SR5
    Still brand new.
    Thanks, the hunt begins for a decent price.
  12. Oct 31, 2009 at 7:13 AM
    grammy
    grammy Well-Known Member
    Newfoundland, Canada
    4x4 v6 X-Cab
    I did the same, put an 09 overhead console in my non TRD and it works fine. Purchased from another member on here for $150 shipped. Good deal.
  13. Apr 17, 2010 at 1:22 PM
    DinaxMaxxum
    DinaxMaxxum Active Member
    TRD Sport
    Same problem..I did order from http://www.*********************/ a 8879022131-GRN270 (Toyota Tacoma Ambient Temperature Sensor, 4.0L (05- ) US$ 12.23 . After desambling under roof connector and well isolate yellow wire (pin #5). I did install a new wire in Pin #5 and #6 (just under pin #1). Both wired wer connected to the temp. sensor placed near the original , in the front of the truck.And work fine.
  14. May 10, 2010 at 1:00 PM
    jassco
    jassco Well-Known Member
    NH
    2023 TRD Offroad
    So from this we can assume that the 4 cyl SR5 AC I have would contain a different AC amplifier and therfore the console swap with another 09 would not work?
  15. Aug 25, 2010 at 4:51 PM
    #35
    navysob
    navysob Carolina Alliance: Virginia Beach and Greenville
    Sean
    Virginia Beach, VA
    09 4x4 SR5
    28/20 Tint, Hood Protector, Vent Visors, 3" AAL's, Front Level Kit, Gas Shocks in the Rear, Tow Hitch, Black Step-Bars, Bull Bar, Off Road Lights
    Just about to ask the same question.... Please some good news would be nice...
  16. Apr 7, 2011 at 8:52 PM
    #36
    petyanca
    petyanca Well-Known Member
    Tacoma, WA
    09 AC 4cyl 4x4 5spd
    I was wandering if someone has been successful with the temp gauge install on a 4 cyl.
  17. Jun 3, 2011 at 6:55 AM
    #37
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    I have a 09 4cyl AC Prerunner, all prewired for a sensor up front and the plug up top. Now I am wondering if it will work if I by the parts?
  18. Sep 2, 2011 at 6:17 PM
    #38
    SGT Taco
    SGT Taco It all fun and games till its not.
    Scott
    Spring Hill TN.
    R.I.P. 2007 TRD, Land Rover Disco II, F250.
    Wife rolled it 3x mod...
  19. Dec 19, 2011 at 4:58 PM
    #39
    Donblonel
    Donblonel New Member
    Hey this was very useful information, I recently purchased a 2005 toyota tacoma, and the outside air console didnt work, went to toyota 7 times to figure out the unit was faulty ordered the wrong part one time, finally got the part in installed it, and i have a compass but the temperature just shows me 3 bars all the time, went back to toyota they told me it was my junction block, being fried, which is not covered on my warrenty, I never changed the junction block because i refuse to believe that it is even fried, now you come out here with pretty much the same issue, the 3 bars, and then the two different part numbers, tomorrow i am going to check out my part numbers with the ones you have listed thanks for the info!
  20. Jan 26, 2015 at 11:18 AM
    #40
    bradforj
    bradforj Well-Known Member
    TN
    07 4x4 v6 TRD Sport
    2012+ Front End Swap 2014 steering wheel swap w/audio and BT controls 2014 power window controls 2014 lower center dash and radio bezel 2014 a/c controls Auto-dimming mirror Heated side mirrors Turn signal side mirrors Backup camera DNX890HD head unit Kenwood speaker system Kobalt slim toolbox In-channel Ventvisors N-Fab running boards
    I know this is an old thread, but I can't help but wonder if the temp probe on an 07 could be wired up to a Gentex mirror. Are the 07 temp probes wired through the A/C, or do they go straight to the wiring harness in the roof?
