Need Help with picking a kit from Crutchfield.
Discussion in 'Audio & Video' started by hockeypoor, Jul 30, 2011.
  1. Jul 30, 2011 at 10:35 PM
    hockeypoor
    hockeypoor [OP] Well-Known Member
    Central Coast of California
    Speedway Blue All stock Prerunner
    Ok I have looked through tons and tons of posts but cant seem find a kit that will include all things needed from 1 place like crutchfield or?
    I have a 2006 DC and would like a single Din HU, front speakers and rear speakers. No amp or sub. Would like the Steering wheel controls to still work, Aux jack and to use stock wiring if possible.
    I like rock mostly but do listen to country, classical and some rap. I like load clean sound with some more bass then stock.
    I will do the install myself and would like to use the adpt in the front doors for more bass.
    Hope that is enough info. Can you please help me pick a complete kit from Crutchfield?
  2. Jul 31, 2011 at 3:11 PM
    hockeypoor
    Come on People.
  3. Jul 31, 2011 at 3:19 PM
    Maverick904
    Maverick904 Resident Fishing Expert
    Kameron
    Northeast Florida
    08 TRD Rugged Trail 4x4
    3" Procomp Lift, BDF Light Bar, Borla Stainless Cat-Back System, 2 10" Polk MM Subs, LED Interior Lighting, Pioneer Touch Screen, Kicker Speakers up front, Sonys in the back, Grillcraft grill, 20% tint, Weathertechs, Projector Retrofit Headlights. BHLM
    Just letting you know..if you go with aftermarket speakers...you probably wont be happy with the amount of bass that they will produce...typically they are less than factory speakers...
    aftermarket speakers are usually designed to be paired with a sub. they are geared to play mids and highs and leave the lows to the subs.
  4. Aug 1, 2011 at 10:48 AM
    hockeypoor
    aftermarket speakers are usually designed to be paired with a sub. they are geared to play mids and highs and leave the lows to the subs.[/QUOTE]
    Not all cars have Subs. Therefor I dont believe that most aftermarket speakers are designed to use with subs.
    In the past I have installed 6x9's with a new HU and gotten A LOT more bass then the stock system had. I am not talking about window breaking bass, just more then the stock crap that I have. I put in Metallica and crank it to max and have to turn the bass down to "0" that is bs.
    My problem is there are so many options I would just like to know what I can BOLT IN using the stock wiring and sound better.
    I think 6x9's in the front would give me a little more punch.
  5. Aug 1, 2011 at 10:57 AM
    fishntaco
    fishntaco Well-Known Member
    Josh
    Mobile Al
    08 Silver Streak DCLB Prerunner Sport
    You can bolt any 6.5 or 6x9 speaker into the stock speaker location. You will have to have adapters to fit both the 6.5 and 6x9 in the stock location. Look for a speaker with a high efficiency level (preferably over 90db) if you plan on keeping the stock headunit, otherwise you will have less volume than stock. There are wiring harnesses that make all speakers plug and play.
  6. Aug 1, 2011 at 11:27 AM
    mattg43
    mattg43 Well-Known Member
    Texas
    08 Prerunner SR5 DC
    SwingCase, driver side. PVC Bike rack. Aftermarket stereo.
    Steering wheel controls - need a device to wire them up, and a head unit that has an output for SWC.
    More bass - Deaden properly, and seal off the door holes.
    louder, but no Amp - Consider an Alpine with their in line amp, that will hide under the cup holders?
  7. Aug 1, 2011 at 4:43 PM
    hockeypoor
    I will check for these items. Hopefully I can find the on crutchfield site.
  8. Aug 1, 2011 at 4:45 PM
    Big D
    Big D Member
    daniel
    alabama
    11 trd 4x4
    planet audio big bang 6.5 front doors sony 4channel amp kicker 6.5 subs rear doors
    go to tacotunes.com they can help.
  9. Aug 1, 2011 at 5:24 PM
    hockeypoor
    This is harder then picking out my new handgun. Way to many to choose from. I give up. I guess I will just take it to the local shop and hope they use lube on me.
  10. Aug 1, 2011 at 5:27 PM
    Maverick904
    Kameron
    Northeast Florida
    Use your budget to help...narrow down the couple speakers that fit your budget...then look for reviews...
    use the reviews to make a final decision.
