Need help with picture download
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Sgt.Tee, Feb 20, 2019.
  1. Feb 20, 2019 at 6:10 AM
    Sgt.Tee
    Sgt.Tee [OP] Well-Known Member
    Pete
    NE Pa
    2019 MGM SR Tacoma 4&4
    is there a thread to follow to download startup picture on the entune radio. I found this but it is not for the Tacoma.
    Here's how to change the startup image on the entune nav:
    Load a usb device, such as a flash drive with the image of your choice. The images file name, including the file extension, can be up to 32 characters. Name the image without spaces or strange characters. When saving the images to a USB, name the folder that the startup image is saved to “StartupImage” and name the folder that the screen off image is saved to “DisplayOffImage”. If these folder names are not used, the navigation system cannot download the images. (The folder names are case sensitive.)
    The images file extension is JPG or JPEG. Image files of 10MB or less can be saved.
    Up to 3 images can be downloaded. Plug the flash drive into your car usb port.
    On the entune nav system:
    Press the “SETUP” button
    Touch “General” on the “Setup” screen.
    Touch “Customize Startup Image”
    Touch “Transfer”
    Touch “Yes”
    You can also delete and switch between screens.
    You should now see your new startup screen flash by when the entune system is started each time.
    If these instructions are correct I will print it out and get to it
    J_Thomas’sTACO and Harley05 like this.
  2. Feb 20, 2019 at 6:26 AM
    WeezyODU
    WeezyODU Well-Known Member
    2017 MGM Sport DCSB
  3. Feb 20, 2019 at 6:27 AM
    WeezyODU
    2017 MGM Sport DCSB
  4. Jan 15, 2021 at 12:17 PM
    YotaQuicksand
    YotaQuicksand New Member
    Cody
    2017 Quicksand Tacoma TRD Sport
    Trifold bed cover. Leather heated seats.
    This is well worth it! Great cheap/easy way to make your interior your own on your Taco!
