Need help with power steering fluid
Discussion in '2nd Gen. Tacomas (2005-2015)' started by motodude95, Jul 6, 2019.
  1. Jul 7, 2019 at 9:07 AM
    Fullboogie
    Fullboogie Well-Known Member
    Dave
    Houston
    2007 Prerunner & 2008 4Runner
    OP, good time to do a full flush. It's really easy and quick. There are a couple of good DIY threads on here on how to do it.
  2. Jul 7, 2019 at 12:02 PM
    Accipiter13
    Accipiter13 Well-Known Member
    California
    '11 DCLB 4x4 Sport
    you can switch back and forth with a clear ATF and maxlife - helps with determining when the flush is done.
  3. Jul 7, 2019 at 12:41 PM
    Yota_Ivan
    Yota_Ivan Geaux Tigers!
    Arlington, TX
    2006 Tacoma DCLB 4x4 TRD Sport
    A little bit of this, a little bit of that...
    Would Castrol Transmax DEX/Merc work? Pretty hard to find an actual DEXRON III fluid .
  4. Jul 7, 2019 at 12:44 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    Toyota power steering fluid is ATF fluid without the Red dye color
    will.i.was[QUOTED] likes this.
  5. Jul 7, 2019 at 1:31 PM
    Accipiter13
    California
    '11 DCLB 4x4 Sport
    The bottle should say what applications it fulfills
  6. Jul 7, 2019 at 5:18 PM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    Yes - research from way back when showed that Toyota uses undyed ATF in their P/S units. A yr. or so ago, I called 6 Toyota dealers n my area - parts dept. - asked what was used in the shop. All said they used plain jane power steering fluid. Go figure?
    So it would seem there are 2 distinct ideas of what to use.
    Regarding the Idemitsu product shown earlier in this thread. Here's some info about it from an online seller of that product:
    12 Ounces. Mineral Based Power Steering Fluid. Engineered for Asian import vehicles Meets: Honda/Acura PSF-S - Toyota/Lexus/Scion D2 - Mazda M3 -Nissan PSF. Idemitsu Lubricants America Corporation is a manufacturer of finished lubricants for a variety of applications including the automotive and in
    Years ago I owned a couple of Honda Accords. Those vehicles used specific P/S fluid for Honda. The Idemitsu product claims to be OK in Honda's and other non-Honda Asian vehicles.
    I wonder how that works?
    Norton likes this.
  7. Jul 8, 2019 at 8:49 AM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    I do a suck and fill on the reservoir with Maxlife ATF every 5k. Been doing that for about 20k miles on my current truck. Our rigs clearly call for ATF. Not sure what all the confusion is about. The truck does not care that it's red in color.
    Also....been using Maxlife in both the transmissions and power steering systems in all of the Toyotas in my family and extended family for years. Zero issues
    JGO and BillsSR5 like this.
  8. Jul 8, 2019 at 8:54 AM
    TacomaSport86
    TacomaSport86 2010 Tacoma/2016 4Runner Pro
    What does your owner's manual recommend? I'd go with that.
    Norton likes this.
  9. Jul 8, 2019 at 12:34 PM
    will.i.was
    will.i.was Well-Known Member
    Will
    Houston, Texas
    SC 2.5
    I've worked on cars for 15 years. Family owned shop of 50 years. Always have used atf for power steering for Asian vehicles. Trust your tech/mechanic but always do your back end research. I have never trusted anyone to work on any of my cars in my entire life for that reason. I break, I cry.
    Very interesting to read the Toyota power steering fluid is undyed atf. Can't say I've heard that before lol
  10. Jul 8, 2019 at 12:36 PM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
  11. Jul 8, 2019 at 12:44 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Yup used Valvoline Maxlife on my power steering. Used only 1 qt. Honestly the easiest and cleanest fluid change you can do on the vehicle.
  12. Jul 8, 2019 at 1:12 PM
    jackn7
    jackn7 Old Man Tan Taco
    Art
    So Cal
    2008 DCLB 4x4
    Just some stuff...
    THIS!!!!!!
  13. Jul 8, 2019 at 1:21 PM
    ResearchMonkee
    ResearchMonkee Techn9cian
    Derrick
    KCMO
    2011 Barcelona Red DCSB Sport
    Did a power steering flush and fill on my taco a couple months ago.
    Used Valvoline Maxlife, works perfect as it is what the owners manual states to do which I'd trust over that one user's mechanic.
  14. Jul 8, 2019 at 1:30 PM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Keep it simple, a quart of Supertech (rated Dexron II and III) at Walmart is only $5. It's just the power steering for goodness sake. Any new clean fluid is better than nothing; no need for anything fancy.
  15. Jul 8, 2019 at 1:31 PM
    #35
    jkuniverse
    jkuniverse Well-Known Member
    Arlington TX
    2013 Limited DCSB 4x4 Super White
    How often are you guys changing the fluid? I didn’t see a change interval in the owners manual.
  16. Jul 8, 2019 at 1:46 PM
    #36
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    IMO depending on the frequency of your driving every 1-2 years. Just keep and eye on fluid color. I bought my truck with 129K and it was black and dirty (as in never changed), but performed OK. No increase in performance other than the piece of mind. Like others posted here it's a 15-30 minute job depending on how you're feeling that day, lol.
  17. Jul 8, 2019 at 2:43 PM
    #37
    nd4spdbh
    SoCal
    I drank a beer first, used that as my return line catch, drank another beer whilst doing the procedure to push old fluid out and topping off the rez before i pulled air. Final top off and rewarded by an after job well done beer.
    Needless to say its a 1 beer job of actual work.
  18. Jul 8, 2019 at 4:00 PM
    #38
    dawgn86
    dawgn86 Well-Known Member
    2013 Toyota Tacoma
    Changed and flushed mine at 60k miles and used Valvoline Maxlife. Took about 30 minutes.
