need help with rack & pinion gear seals
Discussion in '1st Gen. Tacomas (1995-2004)' started by neegdogdig, Jun 17, 2014.
  1. Jun 17, 2014 at 1:52 AM
    neegdogdig
    neegdogdig [OP] Untrained with bad experiences go go go!
    3rd Gen DC V6
    I have an 02. 4 cyl. 2.7l taco and have a power steering fluid leak between the connection of the power steering rode and the rack n pinion where the two join together that hold by 2 bolts. Dont noe whats the problem but thinking the rack n pinion gear seals might have gone bad. Need your expertise advices for the work n repairs your inputs are greatly appreciated. Thanks
  2. Jun 17, 2014 at 1:30 PM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
