Need help with repainting satoshi
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 8th sin, Jun 8, 2010.
  1. Jun 8, 2010 at 7:48 AM
    8th sin
    8th sin [OP] Swollen Member
    Tampa, FL
    2015 DCLB 4x4 Sport
    Llumar CTX Tint, Grillcraft MX Upper, Pro Comp Rockwell 5034 17x8.5, Nitto Terra Grappler G2 LT285/70/17, Icon Stage III
    Howdy, I recently traded in my rad red truck for a super white. I kept my satoshi, figuring it would be cheaper to have it professionally resprayed than to buy a new one outright.
    To save money, I'm going to try and do the prep work myself. I have carefully taped up all the non-red parts of the grille, but I'm not sure how to proceed from there. Do I need to sand, prime, then sand again? There are no imperfections in the paint now, so I'm wondering if I need to sand before I prime. If I need to sand after priming, what grits should I use?
    And if anyone knows a decent paint shop in the DFW mid cities, let me know! Thanks!
  2. Jun 8, 2010 at 8:00 AM
    Ocean's
    Ocean's Well-Known Member
    I'm sorry about your situation. Did the doctor tell you it's curable...?
    Rad Red Rules...lol
  3. Jun 8, 2010 at 8:05 AM
    BigRedToy
    BigRedToy ¯\_(ツ)_/¯
    Colorado
    07 Regular Cab SR5 4x4
    x346564523225
  4. Jun 8, 2010 at 8:21 AM
    8th sin
    Tampa, FL
    2015 DCLB 4x4 Sport
    yea yea...if they still made rad red, I would have gotten one. Super white was my next choice.
  5. Jun 8, 2010 at 8:37 AM
    T0LLPHR33
    T0LLPHR33 Well-Known Member
    S1N C1TY...(from Hilo, HI)...
    BSP TRD Off-Road
    APR X-1 | TRD CAI w/Clear Cover | TRD Short Shifter w/ TRD "RED" Shift Knob | SGII w/Blendmount| Snugtop SL w/KeyLess Entry | 5% Tint | Pop-n-Lock | Bosch Icon WB | S2K Antenna | HRM | LS 8K Projectors w/BSP HLM & 8K Fogs w/FLM | Debadged |Tinted Tails | Black Weathertechs | MX RGM & RBM | Optima Red Top 35 | Gatorback Belt |
    you need to sand then prime then sand again..
    you don't need to get down to the nit and gritty...800 grit then work your way up...I got up to 1000 before priming...after that I sanded with 2000 grit then primed again...once painted i wet sanded...:D
    good luck...just take your time...
  6. Jun 8, 2010 at 11:19 AM
    morphius
    morphius Well-Known Member
    Santa Clara, CA
    2010 4x4 Access Cab TRD Sport
    Is there clear coat on top of your original red? Yeah, you definitely need to sand away to get the primer to bite. Prime.. sand.. base white.. wet sand.. clear coat.. buff.
  7. Jun 8, 2010 at 11:34 AM
    8th sin
    Tampa, FL
    2015 DCLB 4x4 Sport
    There is. I'm only going to prep it through priming and a final sanding. I'm having a paint shop take it from there.
  8. Jun 8, 2010 at 11:44 AM
    tim920
    tim920 Never seen Forest Gump
    Tim
    Boston, MA
    2005 4Runner Limited V6
    No build page?
  9. Jun 8, 2010 at 12:34 PM
    T0LLPHR33
    BSP TRD Off-Road
    RR is nice...if you like pink after a few years...rofl
    j/k
  10. Jun 8, 2010 at 1:51 PM
    tim920
    Tim
    Boston, MA
    ^LOL is it really that bad? Is that why they discontinued it?
  11. Jun 8, 2010 at 2:01 PM
    T0LLPHR33
    BSP TRD Off-Road
    yes it is that bad...i've seen a lot of RR Tacomas whether XR, 4x4, etc...that have turned pink...some have even gone so far to have an orange tinge to them...
    blame it on the clear coat...or blame it on the owner maintenance of the paint/clear coats...either way...PINK FTL...lol
    I'm sure if women knew that the RR turn pink...the RR would be top in female choice of color instead of SWB...
  12. Jun 8, 2010 at 3:19 PM
    Bobcat
    Bobcat Well-Known Member
    Montana
    My RR is a 06 and still perfect.
  13. Jul 24, 2010 at 7:23 AM
    8th sin
    Tampa, FL
    2015 DCLB 4x4 Sport
    Well, I ended up priming it and that went well, so I picked up some color matched aerosol and clear coat and took a shot at painting it myself...Went well until about the third coat of base when the finish started to fisheye..so it's hosed now.
    I took it to a local body shop to get a quote, and they wanted $200 to spray it! They said it was $125 just for the paint and another $75 since they have to strip it down since the paint I used will react with their paint....
    you guys think they are jerkin me around?
  14. Jul 24, 2010 at 7:56 AM
    Viet2100
    Viet2100 Well-Known Member
    Viet
    South Florida
    2016 Prius 4T
    Sounds about right. Sucks when you do not know a friend in the business.
  15. Jul 24, 2010 at 8:38 AM
    doubletaco
    doubletaco Well-Known Member
    Magnolia
    16 Quicksand TRD O/R 4x4
    TRD FJ Wheels, LED Fog lights
    Your better off sanding it down and repainting it again, if you need some help I'm in Bedford.
  16. Jul 24, 2010 at 9:39 AM
    sfoxwoody
    sfoxwoody Well-Known Member
    Calhoun, Ga
    05 TRD Sport, 4x4, BSP, LB
    none yet
    you should have just sold it to me then fixed you another one
