Need help with replaced headlights!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by AJ van TACO-Man, Feb 21, 2010.
  1. Feb 21, 2010 at 1:49 PM
    AJ van TACO-Man
    AJ van TACO-Man [OP] Member
    AJ
    Tulsa
    09 Tacoma Prerunner DCLB
    the headlights that I replaced my factory headlights with are supposed be identical to factory lights, and as far as I can see, they are. they have been installed correctly and to the best of my ability, yet I'm having some trouble with the alignment of the lights and some focusing problems. If anyone has any ideas or experience with these headlights as to how I can adjust them please let me know...
    the lights I installed: factory lights with a black insert.
    the problem that I am having:
    please feel free to provide suggestions if you know anything about them
    also, feel free to ask for additional pictures about what I did to install them, for all I know it is something that I've done.
  2. Feb 21, 2010 at 4:35 PM
    Razorecko
    Razorecko Well-Known Member
    '09 Pyrite DCLB TRD Supercharged
    There are two metal prongs on the back of each headlight with philip screw heads. One adjusts horizontal and one adjust vertical.
  3. Feb 21, 2010 at 9:10 PM
    AJ van TACO-Man
    AJ
    Tulsa
    thanks guys. really appreciate it. different than the headlights that i've adjusted in the past. is it normal to have to move the battery and the reservoir to get to the adjustment screws?
    :confused:
  4. Feb 21, 2010 at 9:13 PM
    WATacoRider
    WATacoRider Well-Known Member
    TRD Sport 4x4
    lol.
    if you have a long screw driver, you can follow the slot right above the adjustment knob. You slide right in and you can see the teeth of the knob. I think there is a white cap on the bottom knob where you have to remove it though.
  5. Feb 21, 2010 at 9:27 PM
    Veinguy
    Veinguy Done, Retired from here :)
    Roy
    Tucson
    2009 Black Tacoma
    Sport Hood ARE LSII Lid Flowmaster Dual Exhaust Airaid CAI Airaid TBS 3" Revteck Lift Tires & Rims Billet Grille Insert Blue LED Dome Light Redline Quicklift Debadged Luminics blue bulbs in the headlights and Fogs N-Fab lightbar Hella 500 x 4 Wet Okole's Blk/Char Weathertec Mats Extra's sshhhhh!
  6. Feb 21, 2010 at 9:32 PM
    AJ van TACO-Man
    AJ
    Tulsa
    think that i figured it out. lol
    feel pretty retarded at the moment for what i was trying to do
  7. Feb 22, 2010 at 10:52 AM
    AJ van TACO-Man
    AJ
    Tulsa
    okay. i've found the adjustment screws and i've fixed that sufficiently, now does anyone know why there is such a focused beam especially on the passenger side light? eventually i want HID 6000k conversion on them but right now, would the Sylvania Ultra bulbs reduce that beam effect that i have on both headlights?
    the 2nd picture on the first post is what im referring to...
  8. Feb 22, 2010 at 11:06 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    The light pattern on the aftermarket lights does not appear to be as good as the stock HLs. My aftermarket lights were the same, each HL had a hotspot, and the light was not distributed very well anywhere else. While the lights look great, this was one of the main reasons I went back to stock.
    As far as a PnP HID conversion, or any other bulb, I would think that the hotspot would just get worse as it's in the reflector, not the bulb (I tried a couple different bulbs myself, not HID though).
  9. Feb 22, 2010 at 11:13 AM
    AJ van TACO-Man
    AJ
    Tulsa
    good to know. and it makes sense that the hotspot is from the reflector and not the bulb. youre right.
    does anyone know anything about a conversion to a projector headlight rather than the reflection type unit? i want to keep similar housing but change the main headlight to a projector, i've seen it on a couple trucks but havent been able to find them since
  10. Feb 22, 2010 at 11:26 AM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    Quite a few have done projector retrofits on here.
  11. Feb 22, 2010 at 12:02 PM
    AJ van TACO-Man
    AJ
    Tulsa
    i have yet to find very many. if you know of some specific helpful projector retrofits that you've seen, please post some of the links. would be appreciated.
    im just doing research btw. the project will likely happen this summer
  12. Feb 22, 2010 at 5:25 PM
    Viet2100
    Viet2100 Well-Known Member
    Viet
    South Florida
    2016 Prius 4T
    The aftermarket lights use paint for the chrome inside your headlamp. OEM headlamps use actual metal for the light coming from the bulb to reflect off of.
  13. Feb 22, 2010 at 5:54 PM
    AJ van TACO-Man
    AJ
    Tulsa
    thats a useful piece of information... wish i knew that would be a side effect of those lights before i bought them. thanks tho! :D
  14. Feb 24, 2010 at 1:43 PM
    AJ van TACO-Man
    AJ
    Tulsa
    well. as far as the adjustment goes, other than the beam itself, i've got the lights looking a lot better:
    thanks guys
