Need help with right rear brake locking up randomly on 09 tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by letz4x4, Apr 10, 2016.
  1. Apr 10, 2016 at 12:00 PM
    letz4x4
    letz4x4 [OP] Member
    Larry
    Butler, Pennsylvania
    2009 toyota tacoma
    None
    R.R brake will be locked up in morning when I back out of garage. Will pull forward and backwards a few times and it's still locked up. Will start to drive for a few hundred feet and brake will release and be fine until I park for a while. Then it starts all over again.
  2. Apr 10, 2016 at 12:17 PM
    Clearwater Bill
    Billy
    Largo Florida
    Is this with the ebrake engaged, then not releasing?
    Or are you speaking of the hydraulic side of things?
    Have you disassembled, inspected, cleaned, lubed yet?
  3. Apr 10, 2016 at 12:29 PM
    letz4x4
    letz4x4 [OP] Member
    Larry
    2009 toyota tacoma
    None
    Does not matter if e-brake is used or not. Still have same symptoms either way. Thinking it's something electrical connected to hydraulics like a solenoid or something. Had both rear drums off to inspect brake shoes, springs and adjustors and all looked good.
  4. Apr 10, 2016 at 12:40 PM
    vbibi
    vbibi Well-Known Member
    san fransisco bay area
    2009 4door long bed
    Are you backing up and retrieving a boat trailer from the ocean.
  5. Apr 10, 2016 at 12:55 PM
    letz4x4
    letz4x4 [OP] Member
    Larry
    2009 toyota tacoma
    None
    No. Nothing out of the ordinary. No off roading or modifications.
  6. Apr 10, 2016 at 4:39 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Parking brake pivot under the rubber boot.
  7. Apr 10, 2016 at 6:18 PM
    letz4x4
    letz4x4 [OP] Member
    Larry
    2009 toyota tacoma
    None
    Thanks maineah. I will check it out tomorrow. Any more info will help. I will let you know what I find
  8. Apr 12, 2016 at 2:26 PM
    hotrod53
    hotrod53 Well-Known Member
    Lynd
    Pittsburgh, PA
    ‘14 DCLB Sport, ‘18 TCH, ‘13 TCH
    Weathertech floor liners moded to hold OEM floor mats, weathertech vent visors, Toyota bed mat, LEER 100XL cap, hood gasket mod to stop whistling.
    My '06 did that, it was failed e brake cables. Happened to me at 125,000 miles. Put a hurtin on my brand new brake drums that are over $100 each.
  9. Apr 12, 2016 at 5:22 PM
    letz4x4
    letz4x4 [OP] Member
    Larry
    2009 toyota tacoma
    None
    Just finished replacing both e brake cables, brake shoes and spring hardware. I hope that takes care of the problem. Should know in a couple days. Thanks to everyone for the replies. Becoming a member of tacoma world was one of the smartest things I have ever done.
    hotrod53 and o0oSHADOWo0o like this.
