Need help with rubbing
Discussion in '3rd Gen. Tacomas (2016-2023)' started by VoodooBluTaco12, Apr 12, 2021.
  1. Apr 12, 2021 at 7:14 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    thats probably a cab mount relocation. You will eventually need a chop, maybe not that extreme. Sarcasm doesnt translate through the internet that well
  2. Apr 12, 2021 at 7:14 PM
    Vegasstunts
    Vegasstunts Well-Known Member
    16 TRD sport
    All of them.
    This is for a cab mount relocation. Only necessary if you're going to 35s or 33s with crazy offset.
  3. Apr 12, 2021 at 7:15 PM
    VoodooBluTaco12
    VoodooBluTaco12 [OP] Well-Known Member
    Dylan
    2021 Voodoo Blue SR5
    Ah I see. That makes sense and thanks for elaborating on that. I’ll probably spend a good chunk of time tomorrow doing some trimming and such but I’ll make sure to point out where contact is being made first so that I have a sure idea where and how to go forward.
    hiPSI[QUOTED] likes this.
  4. Apr 12, 2021 at 7:15 PM
    timred93
    timred93 Never too old to Tacoma
    Tim
    NW AR
    2013 Spruce Mica TRD Sport
    Predator Tube Steps, Fuel Hardline Wheels, 265/70 R 17 Nitto Ridge Grapplers, 2 inch Rough Country Leveling Struts, Undercover Armour Flex Hard Folding Tonneau Cover, Pop and Lock Tailgate Latch With Key Lock.
    This!
  5. Apr 12, 2021 at 7:15 PM
    fatfurious2
    David
    Ashburn, VA
    heat gun, and a BFH (big fucking hammer) (or a mini sledge to make things flatter)
  6. Apr 12, 2021 at 7:15 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    It means go get it aligned and instruct the tech to push the caster positive as far as it will go. This means, to a layman, moving the wheelbase further apart. It actually is a good thing because we are only talking about a quarter inch or so.
  7. Apr 13, 2021 at 7:44 AM
    FishaRnekEd
    FishaRnekEd Well-Known Member
    New Orleans, LA
    2005 4.0 6spd 4x4 Dbl Cb short bed
    It was a bad joke. If you're tire keeps rubbing to plastic under the wheelwell, it will wear a hole in the plastic. Tgen you won't have anymore rubbing. LoL, took mine about 6 months
  8. Apr 13, 2021 at 4:08 PM
    VoodooBluTaco12
    Dylan
    UPDATE: Did some trimming of the fender/fender lining and that seemed to do the trick but I plan once I’m back to my tools, I’ll use a heat gun as well to mold some of the fender lining as a precaution.
    Aqualoon and timred93 like this.
