Need help with shudder/vibration
Discussion in '1st Gen. Tacomas (1995-2004)' started by 04whitetaco, Nov 19, 2014.
  1. Nov 19, 2014 at 6:08 AM
    04whitetaco
    04whitetaco [OP] Member
    New York
    2004 Tacoma, v6, SR5, 5speed,
    Eibach/billstien 3" lift, Pro Comp wheels, 285 Kenda klevers, flow master 40 series, deck plate, full amsoil.
    So I have been fight this shudder/ vibe for a while replace carrier bearing and dropped carrier 1-1/2 and still get a shudder almost like snow in the tires at 30 and 50 and then it vibrates bad after 65 and up had tires balanced and rechecked 2 times also moved tires around and no diff ....I'm at my whits end with this any other ideas what to check or do I have billstien 5100 lift in front with block in rear. PleSe advice will be much appreciated. . Thanks TW!!
  2. Nov 19, 2014 at 6:13 AM
    LIKURMoMsTaco2
    LIKURMoMsTaco2 Ebola Free 53 years
    The Player
    Not your mom's taco
  3. Nov 19, 2014 at 6:51 AM
    04whitetaco
    New York
    3 inch lift . I also have tried diff amount of drops
  4. Nov 19, 2014 at 7:20 AM
    04whitetaco
    New York
    Only thing I haven't tried is to run no carrier drop and flip the carrier bearing, I tried flipping it with diff amounts of drop but not with no drop, i also have another set of rear lift blocks the are degreed 3* degrees that I might try. It's just weird Tru k was comp fine then I did lift and got alignment and tires balanced and it's don't it since the moment I pulled out of the garage and drove it, moving the carrier bearing seems to just change how much or WHT speed it shudders or vibrates at, and it doesn't change at all when in 4wd it's def in the rear end and drive line I'm just confused on what to do all u joints are greased and working and in good shape truck only has 70k on it too.....
  5. Nov 19, 2014 at 11:38 AM
    knuckleduster271
    knuckleduster271 Well-Known Member
    Baron Longrod Von Hug€nschlong
    ohio
    98 sr5 xtra cab
    881's, 5100's, soft 8's, elocker, matrix seats, smittybilt xrc8.
    Have you replaced your u joints? Specifically the one in front of the rear diff?
    I had pretty much the same symptoms as you with a low mile truck after I lifted the rear... it wasn't but about six weeks after my rear u joint was shot.
  6. Nov 19, 2014 at 12:06 PM
    04whitetaco
    New York
    I checked it and it functions and feels tight and smooth ..... and I checked it with the drive shaft unhooked. And truck was comp fine when I drove it in and after I drove out after the install I have had this issue ever since and have tried multiple things ....how many people are lifted and not running a carrier drop at all? Seems like some things work and some don't for people doesn't me sense
  7. Nov 19, 2014 at 12:11 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    it all depends on the drop, each drop is different so maybe you need a bigger carrier drop or less of a carrier drop but you need to do the calculations so the angle of the rear end matches the angle of the tranny so it doesn't bind the u-joints and make the truck vibrate
    you might get lucky but in most cases you cant just drop in a standard spacer used for all trucks because in reality one doesn't really exist even though thousand are driving with something that is "close enough" because they didn't do the calculations to get the correct one.
    to lift your truck and maintain the proper drivetrain operation, you should calculate your drivetrain angles and use the correct sized spacer that the calculations say you need.
  8. Nov 19, 2014 at 12:13 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Those blocks though.
  9. Nov 19, 2014 at 2:08 PM
    keakar
    karl
    louisiana
    yep, when people do this I wish they would think to paint them and the u-bolts black so it doesn't stand out, why make a turd more visable.
  10. Nov 20, 2014 at 3:23 AM
    04whitetaco
    New York
    Might just say screw it and put in a 1 peice drive shaft and be done with the problems of the crappie design
  11. Nov 20, 2014 at 4:00 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Find yourself some steal 2.5degree axle shims and put everything else back to stock.
  12. Nov 20, 2014 at 4:21 AM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    Not a bad idea.....
    Yeah, any time I have ever used blocks I was sure to use angled ones to eliminate any possible vibration issues....
  13. Nov 20, 2014 at 3:58 PM
    04whitetaco
    New York
    Also at 50 when it begins to shudder or shake if I hold 50 mph and hold brake on it makes the shudder and Vibration way worse .....???
  14. Nov 20, 2014 at 5:43 PM
    keakar
    karl
    louisiana
    that sounds like u-joints, bearings, or loose front end because if it were brakes it would only vibrate when braking
  15. Nov 20, 2014 at 5:46 PM
    keakar
    karl
    louisiana
    angled blocks are "almost" NEVER the right angle (unless you are one in a thousand to get that lucky) and often you are only just "close enough" not to have "major" vibrations. even with angled blocks you need to calculate your angles and add the correct shims in addition to the blocks angle so it will not vibrate. sometimes the angled blocks are angled too much or not enough so you have to do your calculations so you aren't wearing out u-joints and stressing other parts too much.
  16. Nov 20, 2014 at 6:01 PM
    davidpick
    davidpick NWXPDTN
    David
    Leavenworth, WA
    1988 Pickup 22R 5sp 2wd
    Weber 32/36, RV Cam, LCE exhaust headers, Desmogged
    Your truck a 4x4? Try removing the rear driveshaft completely and running around town and on the freeway at various speeds in 4H. That should tell you if it's in the driveshaft or tires/something else.
  17. Nov 20, 2014 at 6:06 PM
    bry838
    oregon
    I very much agree......but it will always be better than nothing at all.
  18. Nov 20, 2014 at 6:12 PM
    keakar
    karl
    louisiana
    yep, they are designed to get you "close" so you don't need to add huge shims and I posted that mainly as a "heads up" to others so they don't assume the angled blocks are all they need. a lot of people are lazy and look to take short cuts assuming things like that so I just felt the need to put that info out there.
  19. Nov 21, 2014 at 1:09 PM
    LIKURMoMsTaco2
    The Player
    Not your mom's taco
    I was pointing out the driveline spacer.
    Blocks, Spock, who cares. I will get there. Other stuff takes precedent... LOL
  20. Nov 21, 2014 at 1:11 PM
    LIKURMoMsTaco2
    The Player
    Not your mom's taco
    The driveline tech that I went to told me Tacomas are KNOWN for having CRAP drivelines...
