Need help with spacer lifts
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tacopaco98, Jan 30, 2025.
  1. Jan 30, 2025 at 3:35 PM
    Tacopaco98
    Tacopaco98 [OP] Active Member
    Timmy
    2021 Tacoma sr5
    Hey everyone I'm not sure if this has been covered but , i know i know that spacers are normally a big no no…But in my head i’m not going to be wheeling at all and i wanted a cheaper temporary fix for now. I need your guys opinions on doing 2/1 spacer lift or 3/2 spacer lift , what are the pros and cons of each ? And what to watch out for when doing either or ?
  2. Jan 30, 2025 at 3:37 PM
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    "A cheaper and temporary fix" for what?
  3. Jan 30, 2025 at 3:37 PM
    Clearwater Bill
    Billy
    Largo Florida
  4. Jan 30, 2025 at 3:39 PM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Welcome, Timmy.
    This subject has been covered extensively, but as others have asked, what are you trying to fix?
    gudujarlson and Chew like this.
  5. Jan 30, 2025 at 3:42 PM
    Tacopaco98
    Timmy
    2021 Tacoma sr5
    Hey guys sorry for the miscommunication , there’s nothing really needing to be "fixed” i just meant i wanted to lift my truck up with leveling kit since it’s cheaper alternative. I know its normally not recommended.
  6. Jan 30, 2025 at 3:44 PM
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    Don't go more than 2/1.
    na8rboy, Chew and Tacopaco98[OP] like this.
  7. Jan 30, 2025 at 5:38 PM
    Clearwater Bill
    Billy
    Largo Florida
    Level is a looker thing. Which is fine if you never haul or tow.
    Rake is engineered in for a reason.
  8. Jan 30, 2025 at 5:44 PM
    IrishRed
    IrishRed Appalachian Ridgerunner
    Central PA
    2017 TRDOR DCSB 4x4 MGM Prem&Tech Auto
    Eibach Suspension, JBA UCA’s, 16” SCS Ray 10s, BFG KO3s, ECGS Bushing, Pro Skid Plate, Fumoto Valve, Pro Grille, Opt7 Tailgate Light Bar, AVS Window In-Channel Vents, Roknlokz XL Mud Flaps, Husky Floor Mats, Bed Mat, Tailgate & Glovebox Letter Inserts, TRD Grille Badge, Exhaust Tip, Toyota Hitch Plug.
    Bilstein 5100’s with factory coils and a 1” block in the rear. Not terribly expensive and way better than spacers. You’ll be so much happier!
    PoolFixer, Tocamo and Tacopaco98[OP] like this.
  9. Jan 30, 2025 at 7:14 PM
    Tacopaco98
    Timmy
    2021 Tacoma sr5
    any thoughts, comments or opinion on wether i should do 2/1 or 3/2 ?
  10. Jan 30, 2025 at 7:16 PM
    Bishop84
    Bishop84 Well-Known Member
    2 or 3" will result in the axle vibration, making it cost more money because it will need the ECGS installed.
    Stick to 1-1.5" for a "cheap" lift. Spacers just didnt work well on 3rd gens.
    Bilstien 5100s are cheap, don't need the bushing and ride waaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaay better than stock.
    PoolFixer and Chew like this.
  11. Jan 31, 2025 at 3:42 AM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    If your set on a spacer lift don't go over 2" these trucks do not behave well over that.
    Chew likes this.
  12. Jan 31, 2025 at 4:10 AM
    skidooboy
    skidooboy titanium plate tester
    central lower mich
    2019 Tacoma Sport KDMax Tuned, Cement
    dd light bars, trd cat back exhaust, KDMax tuned, trd skid plate, 2" lift, sema wheels toyo open country at3 tires.
    If you want/have to go with spacers, two inch max up front, and a 2 inch block in rear. My advice is not to "level" the truck during the lift. if you go 2x1 and it is level, as soon as you put a feather in the bed, the rear will start squatting. Ski
    Chew likes this.
  13. Jan 31, 2025 at 11:12 AM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Chew likes this.
  14. Jan 31, 2025 at 11:25 AM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    Its Friday and I'll take the bait. Don't do a spacer lift and here is why:
    The spacer (assuming a 2" spacer) will go between the coilover top hat and the coilover bucket. When you install this, it will move the coilover down 1" and push the lower control arm down 1" where the bottom of the coilover connects to the LCA. This will push the lower ball joint down 2" and thus, the spindle will be 2" lower and/or the truck will be 2" taller. The part that starts to get dicey is that the bump stop is now no longer used and the coilover becomes the upward limiting part of the front suspension. This will cause the coilover to self destruct over time. Inversely, when the suspension is fully extended, the control arms are forced to droop lower than engineered and the front half-shafts (assuming you are 4WD) will be put in a bind and will also self destruct.
    So the people suggesting the Bilstein 5100 are actually trying to help you save money. You can use your factory springs on the 5100's and choose how much lift you want to achieve all while using your factory bump stops and you wont alter the factory travel of the suspension so the CV's wont wear out any faster.
    If you are 2WD, then you can use a spacer and put a spacer on your bump stop and be fine.
    Chew likes this.
  15. Jan 31, 2025 at 2:13 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Bingo!!! Timmy, your butt will love you for it...
