Need help with stereo problems
Discussion in '1st Gen. Tacomas (1995-2004)' started by JTacoma, Aug 12, 2011.
  1. Aug 12, 2011 at 7:49 PM
    JTacoma
    JTacoma [OP] Well-Known Member
    Washington
    1995.5 2.7 4X4 5 speed
    Icon Stage 2 Coilovers, Camburg UCAs, 33x12.50x15 Dick Cepek Trail Country EXP on American Racing AR201 15x10 wheels, differential drop, carrier bearing drop, BPV bracket, Leer canopy with Rhino Racks
    When i bought the truck the previous owner installed an alpine stereo, two speakers in the back. two tweeters in the front, and wired it for an amp and 2 subs.
    In the spring when it rains a lot or in the winter when it is cold the speakers crackle all of a sudden and then shut off al sound completely. The stereo is still on and the cd will play and i can change the station but no sound.
    When the passenger door is opened then shut or bumped the sound comes back on.
    This has only happened a few times so I didn't investigate and it only happened in the rain or cold until today.
    I drove on rough gravel washboards and the speakers shut all sound off but this time they won't come back on.
    I think the problem is in the passenger door.
    Anyone know what is wrong or how to fix it? Or at least tell me how to remove the door panel on a 1995 tacoma?
    Thank you for the help.
  2. Aug 12, 2011 at 7:52 PM
    JTacoma
    Washington
  3. Aug 12, 2011 at 10:11 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    sounds like a bad cable somewhere. Check the amp. Is the protection light on?(power light is red instead of green)
    Check the power cable running to the amp from the battery.
    check the ground cable to amp.
    then check all the speak wire connections
  4. Aug 20, 2011 at 5:19 PM
    JTacoma
    Washington
    Thanks for the help. I'll take a look.
