Need help with temerature sensor 98 22re
Discussion in '1st Gen. Tacomas (1995-2004)' started by yellowdog5, Jun 29, 2025 at 12:54 PM.
  1. Jun 29, 2025 at 12:54 PM
    yellowdog5
    yellowdog5 [OP] Well-Known Member
    2002 Tacoma SR5 4wd 2.7L
    I ordered an ECT sensor for my 98 2.4L motor, either I got the wrong part or I am trying to replace the wrong thing. The Toyota part that was listed is 89422-35010. It does not work for the one at the front of the engine by the top radiator hose. am I looking in the wrong place? I am led to believe there is another sensor somewhere at the back of the engine, is that the one I am looking for and if so how do I find it?
  2. Jun 29, 2025 at 7:18 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    I believe that one is for the rear? There is this one, check resources to verify it fits your motor but from what I see it should.
    GAGE ASSY, WATER TEMPERATURE SENDER 83420-20040
  3. Jun 30, 2025 at 12:44 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    they prob sent u the CTS for the cluster gauge.....that is under coil packs on pass side
    you need the CTS that is located on rear of head next to firewall
  4. Jun 30, 2025 at 3:45 PM
    yellowdog5
    Okay I got the correct one then, thanks :)
