Need help with tire and wheel size
Discussion in 'Wheels & Tires' started by JMuFF808, Feb 27, 2013.
  1. Feb 27, 2013 at 11:14 PM
    JMuFF808
    JMuFF808 [OP] Member
    Kauai
    2012 4wd TRD off
    Hi I'm new here but heard this is the best place to get answers on tacoma's anyways I was wanting to know if Nitto trail grapplers 265/70r17 on Fuel hostage 17X8.5"/6x5.5" 25mm offset 135mm backspace 87.10mm hub bore, fit on a stock 2012 access cab Tacoma
    Thanks in advance for any help received
  2. Feb 28, 2013 at 3:59 AM
    blaine546
    blaine546 Active Member
    blaine
    rockport
    07 tacoma trd sport
    3'' pro comp front lift, all pro leaf springs. afe intake, avid offroad light bar
    I would say yes, that's not too much bigger than stock, might get tight to your uca's
  3. Feb 28, 2013 at 4:20 AM
    mattmyster
    mattmyster Well-Known Member
    matt
    nova scotia
    07 4 door trd offroad radiant red
    Kenwood DD deck, XD 17in rims, 285/70 firestone destination A/T, ,7in spotlights behind the grill, satoshi grill and color match, rough country lift, seat covers...maybe more cant remember
    im not 100% but i dont think they will fit, im pretty sure the hub bore needs to be atleast 106mm
  4. Feb 28, 2013 at 7:13 AM
    aubi1414
    aubi1414 War Eagle!!
    Justin
    Pensacola, FL
    2014 Tacoma TRD Sport Blue Ribbon Metallic
    LED Dome, LED Map, LED License Plate Bulbs, , Konig SixShooters Matte Black, Toyo Open Country ATII's 285 70 17, Satoshi, Bilstein 5100s (set to 0), 885s, LR UCA's, Icon RR 2.0 +2, All Pro Standard 3" Leaf Pack, All Pro Flip Kit, Sway Bar Relocate, Exhaust Chop, Antenna X 14", Debadged, Tint, Matt123 Black TRD Skid, Black Weathertech Mats
  5. Feb 28, 2013 at 7:15 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    ^^this. toyotas have a big hub bore. those wheels may be for a chevy w/ the same bolt pattern, but smaller hub.
  6. Feb 28, 2013 at 11:03 AM
    JMuFF808
    Kauai
    2012 4wd TRD off
    Thanks for the help, so what I'm getting so far is that the tires would be fine but the wheels are not for a Toyota
  7. Feb 28, 2013 at 11:07 AM
    The_Hodge
    SC
    correct. that size can be run on stockers w/o issue.
  8. Feb 28, 2013 at 11:13 AM
    Mademan925
    Mademan925 Senor Taco
    Nick
    Discovery Bay, CA
    2014 4x4 TRD OFFROAD DCSB
    enough to go over stuff
    I have a 2 inch lift on the front. I did 17*8 wheels with 4.5 back space and 265/70/17 goodyear wranglers. With the back space and lift it was still a close fit. I had to take my mud flaps off.
  9. Feb 28, 2013 at 11:17 AM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
  10. Feb 28, 2013 at 11:56 AM
    JMuFF808
    Kauai
    2012 4wd TRD off
    How much backspacing and offset should I be looking at
