Need help with trailer converter
Discussion in 'Towing' started by ezjumper8, Dec 10, 2019.
  1. Dec 10, 2019 at 8:26 AM
    ezjumper8
    ezjumper8 [OP] Ethan
    ethan
    camp pendleton, ca
    white tacoma dbl cab 4WD sport
    20% tint all around, blacked out badges, flowmaster 40 series and tip, rock hood deflectors, window deflectors, home made baja bumper, 17" XDseries wheels on some nitto terra grapplers, bright white led interior lights, blue needle on white gauges, cb antenna, with cobra radio.
    I bought a toy hauler and when i plug the trailer to a 120volt source the converter does not step it down to 12 volt when connected to the trailer fuse block. I pulled the batteries out of the trailer also because they were only showing 6 volts so i need to replace them.
    I then pulled the converter out of the trailer and wired it up so it can be plugged into a wall outlet. It then was putting out 13.6 volts. I reinstalled it back in the trailer, and hooked it up to the fuse block and plugged the trailer back in and it was only reading .53 volts. Is this a sign that the converter is shot? i would think that if that was it the converter wouldnt step it down to 13.6 volts when plugged in to the wall.
    any help would be greatly appreciated.
  2. Dec 10, 2019 at 8:30 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Are you measuring upstream of the fuse block after reinstalling?
    Pull all of the fuses and measure at each terminal.
