need help with trailer lights ASAP
Discussion in 'Towing' started by 98_Mud_bug, Oct 2, 2011.
  1. Oct 2, 2011 at 11:09 AM
    98_Mud_bug
    98_Mud_bug [OP] 98_mud_bug
    lucedale Ms.
    98 tacoma sr5/ 06 x-runner
    3 inch suspension lift, night shades corner and blinkers projector headlights with halos and 3 led's 18 inch kmc xd rockstar wheels,275/65/18 kelly safari tsr's, bush whacker fender flares 7 inch touch screen, 2 kenwood 12's, Magnaflow exaust single in dual out,
    We are trying to hook up our Boy scout trailer to my dads 03 double cab, and it is a 7 pin so we got a 4pin to 7 pin adapter. well we plugged it in and the lights worked for a few minutes, we had brake lights, and blinkers but no running lights. well we started tracing wires out and could never find a problem in the wires with the test light. we made it back to the contoller box that is behind the back seat and we didnt have any connections that were hot. now none of the lights work. no brakes or blinkers or anything, I have checked all the fuses under the dash and under the hood. any help would be greatly appreciated.
  2. Oct 2, 2011 at 11:27 AM
    Tacoma Mike
    Tacoma Mike 43 Year Toyota Master/ASE Master Tech.
    Southern Maine
    2011 Double Cab V6
    Large Storage Box, 02610 intermittent switch swap, "Hot Wire" Power Outlets, DRL Shut Off, Disable Fob Beep, Disable Seat Belt Buzzers, Parking Light Mod, Battery Tender, 4 Leaf Spring Pack, Rear Headrest Removal, Custom Ultragauge Mount, Factory Tow Package (7 Pin) Rear Diff Mod, Taco Lean Mod
    Unplug the trailer and see if you have everything in the truck.
    If you have a test light you can probe the connector on the truck.
    That will help you look at the trailer or truck for the problem.
    Possible a bad ground on the trailer if you have truck lights and output at the 7 way.
  3. Oct 2, 2011 at 11:35 AM
    98_Mud_bug
    lucedale Ms.
    everything on the truck works fine. thats whats confusing me. all the lights worked but now they dont. it sounds like a blown fuse but i have checked all of them.
  4. Oct 2, 2011 at 11:41 AM
    Tacoma Mike
    Southern Maine
    2011 Double Cab V6
    Ok. the truck works fine now.. So the truck is not the issue.
    If you can see if you have power at the 7 way then we can eliminate something.
    If you don't have power to the 7 way lamps, turn, brakes then it sounds like you lost the box. Remember your only using a few connectors on that adapter. make sure your probing the ones you need.
    This isn't a factory tow package is it ??
  5. Oct 2, 2011 at 11:57 AM
    98_Mud_bug
    lucedale Ms.
    yes it its factory, i was thinking somebody spliced it in but it has toyota stamped in it. im thinking the box went bad.
  6. Oct 2, 2011 at 12:01 PM
    Tacoma Mike
    Southern Maine
    2011 Double Cab V6
    I agree.
    FYI i can't remember off the top of my head but some of the earlier ones had an inline fuse to protect the box. I'm not saying yours has one but just do a quick look around. sorry I can't help you more.
    Hope you get those scouts to camp.......
  7. Oct 2, 2011 at 1:17 PM
    98_Mud_bug
    lucedale Ms.
    i found it, there are 4 inline fuses below the box and one of those were blown. sweet relief because the box is expensive. and we actually just got back from camp this mornin.
  8. Oct 2, 2011 at 1:25 PM
    Tacoma Mike
    Southern Maine
    2011 Double Cab V6
    ALRIGHT!!!! GOOD FOR YOU.
    Guess the top of my head still has something in there.. :goingcrazy:
