Need Help with Tread Depth
Discussion in '5 Lug' started by willida33, May 6, 2011.
  1. May 6, 2011 at 10:09 AM
    willida33
    willida33 [OP] Member
    Dan
    Seattle, WA
    05 SR5 5 Lug
    Chrome 16" wheels, D-rings
    Found a set of 4 Toyo A/T Open Country 265/75/16 for sale for $125/set on CL. The seller sent me some extra pics and he says he thinks they have about 25-50% tread left. I attached a couple pics to see what everyone else thought about the tires, as I think it would be a good deal if around 50% left. I do have aftermarket 16" rims already on the truck and will be adding the Fat Bob's lift.
  2. May 6, 2011 at 10:11 AM
    TACOMA TRD
    TACOMA TRD Well-Known Member
    Tom
    PA
    2011 MGM SPORT DC 4x4
    Alpine HU, Apline 6.5 3 way Speakers, Access Cover.
    That looks to be correct. keep in mind when you buy tires worn like this they tend to be loud going down the road.
  3. May 6, 2011 at 10:17 AM
    Tacomanator
    Tacomanator Boiling denim and bangin whores
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    Save your money. Those tires don't have too many miles left on them. You'll be buying tires again in no time.
    Those are an awesome tire when brand new though.
  4. May 6, 2011 at 10:20 AM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    those tires like they will go 15k more...toyos go forever. Get a pic with a penny in there to get an accurate reading on a pic.
    For 125bucks, can't go wrong!
  5. May 6, 2011 at 10:21 AM
    Mescalero
    Mescalero Beretta Taco
    Clemson, SC
    '10 PreRunner DCLB BSP
    5100's x 4, radar detector, dual usb plug, mag-light, satellite radio hard wire
    thats kinda my thoughts as well...
  6. May 6, 2011 at 10:39 AM
    05RedTaco
    05RedTaco Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
    I would jump on it.... Toyo's are great! I bought 31x10.5x15 tires from used tire place in December, mounted and balanced for $200, they had about 40-60% tread left, so far they are great, well way better than the stock Dunlop Grandcraps...
  7. May 6, 2011 at 11:11 AM
    Tacomanator
    Clam Slammer
    Southern Cali
    my only problem with these tires are "safety". sure they may be able to go for a few thousand more miles, but can they do it safely? They will most likely handle like crap both on road and off road. Tire shops may not even mount those tires for you because of how worn down they are.
  8. May 6, 2011 at 11:18 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Inspect them carefully for damage, inside and out.
  9. May 6, 2011 at 11:28 AM
    KenLyns
    KenLyns 8-in. Third Member
    Belly of the Beast
    4x4 TRD Off Road Full-Auto
    All-Pro Bumper, CBI Sliders, Icon Coilovers, BudBuilt Skids, aFe Intake, Icon VS Rear Shocks, Timbren Bumpstops, All-Pro UCAs, JDM Steering Wheel, ViAir Compressor, Klearz LED 3rd Brake Light, Pop-N-Lock Tailgate Handle, Husky Front Flaps
    ^This. And sometimes damage doesn't become apparent until you mount and inflate the tire, then you discover bulges on the sidewall.
    As for tread depth, it depends on your definition of "acceptable" performance. According to TireRack's tests in 2007, wet stopping distances doubled with 2/32" tread depth versus new, due to hydroplaning, while dry traction wasn't affected much.
    http://www.tirerack.com/tires/tests/testDisplay.jsp?ttid=85
  10. May 6, 2011 at 11:30 AM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    X2
  11. May 6, 2011 at 11:30 AM
    skybob
    skybob Well-Known Member
    I'd say they have about closer to 20 percent than 50 on tread wear, but for 125 bucks, what do you expect lol.
  12. May 6, 2011 at 11:36 AM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    Get a tread depth gauge and measure them. Compare that with how much depth they have new.
  13. May 6, 2011 at 9:22 PM
    05RedTaco
    Tony
    Scottsdale
    I live in AZ so we have about 95% dry weather...lol
  14. May 6, 2011 at 11:32 PM
    willida33
    Dan
    Seattle, WA
    05 SR5 5 Lug
    Definitely going to pass. Hearing about the stopping distance increase doesn't sit well in the Seattle area. Haha. Thanks for all the information.
