Need help with trouble shooting
Discussion in '1st Gen. Tacomas (1995-2004)' started by Kingcat, Oct 21, 2010.
  1. Oct 21, 2010 at 7:50 AM
    Kingcat
    Kingcat [OP] New Member
    Sanford,fl
    O2 prerunner sr5
    My o2 was sputtering out between 50 & 70 mph so took it to shop where they plugged it up an they told me o2 sensor . so I changed o2 an still have same problem .any suggestions?
  2. Oct 21, 2010 at 7:57 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    What was the code?
  3. Oct 21, 2010 at 8:01 AM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2014 DCSB TRD 4x4
    did you change the correct o2 sensor?
  4. Oct 21, 2010 at 8:01 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Yeah, and there are TWO oxygen sensors on the truck.
    Kingcat, which O2 sensor did you change?
  5. Oct 21, 2010 at 8:03 AM
    tt07
    tt07 Well-Known Member
    north carolina
    01 4wd
    none yet
    just had the same thing and mine was bank1 and had a coil going out and a spark plug cracked!! So new O2 and coil pack new plugs and cleaned the mass air and runs better than new!!
  6. Oct 21, 2010 at 9:24 AM
    Kingcat
    Sanford,fl
    O2 prerunner sr5
    I changed the upstream sensor . Some one told me I should look into the plug wires or maybe the fuel filter. Oh an I've already put in new plugs
  7. Oct 21, 2010 at 9:42 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    So you don't know what code popped (check engine light)?
  8. Oct 21, 2010 at 10:07 AM
    stucksucksnayota
    stucksucksnayota Well-Known Member
    Barry
    Fort Smith, Arkansas
    14 Taco 4x4 TRD Sport DCSB
    OEM roof rack, Shorty antenna (eBay), soft tonneau cover, K&N drop in air filter, bed mat, interior LED lights, 5100's, MT tires to come soon!!!
    If it is sputtering and running bad I would check you plugs, plug wires, and coils. I had a plug wire that get against the engine and melted it almost in half which made my truck start running like shit!
