need help with turn signal bulb
Discussion in 'Lighting' started by taco man31, Nov 23, 2008.
  1. Nov 23, 2008 at 5:49 PM
    taco man31
    taco man31 [OP] Well-Known Member
    hi guys. Anyone know where i can find a RED rear turn signal for my 2009 taco. Just having a hard time finding a red bulb that fits. (By the way, is this illegal?)
  2. Nov 23, 2008 at 6:12 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Sounds to me like he wants his turn signal to match the brake light color? Factory turn signals are Amber.
  3. Nov 23, 2008 at 6:15 PM
    pidro_el_pirata
    pidro_el_pirata Well-Known Member
    True, but there are plenty of cars out there that use brake lights as turn signals. IMHO it shouldn't be illegal. Change brake lights or headlights diff. colors should be, but not turn signal to red.
  4. Nov 24, 2008 at 7:09 PM
    taco man31
    Thanks guys for the help. Idk why toyota changed to all LED lights but left the turn signals with a bulb.
  5. Nov 25, 2008 at 3:37 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    This is quite common. My Wifes Hond Accord has rear LED brake lights, and regular lights, but the turn and back up lights are incandesant. I guess it saves a few bucks, and multiplied by the thousands produced, it saves a lot of money.
  6. Feb 25, 2010 at 2:17 PM
    twistax
    twistax Toyota Freak
    Carlsbad NM
    2017 Tacoma 4x4 Off-Road
    CaliRaised ditch mounts & Side Projecting pods
  7. Mar 5, 2010 at 9:06 AM
    Agent475
    Agent475 "Mark It Zero"
    Waldorf, MD
    2006 Red TRD Sport
    Hood Struts, 3" Tuff Country Lift, Shortie Antenna, WeatherTechs, Tinted front windows, custom TRD seat covers, custom pedals, debadged, custom USMC badging, quasi-functional hoodscoop (i.e. I cut it open), black front Yota emblem, Tailgate Theft-Prevention mod, Horn Relocation mod, Old Man Emu Carrier Bearing Drop, Brighter Backup Lights Mod, Smittybilt Reciever Hitch Tow Point, currently working on Satoshi Grill Mod
    Here is some info from SuperBrightLEDs, which might explain why they were incandescent vs. LED.
    Turn signal issues with LED bulbs
    LED brake/tail lamps will not flash with thermal flasher units due to their extremely low current draw. Also, with stock flasher units, the turn signals may flash faster than normal (Hyper-Flash). These installations will require an electronic flasher unit, available in our car bulb shopping category (for some vehicles) or at your auto parts store. Try to find flashers designed to work with LED bulbs, they will say "LED compatible". Often HEAVY DUTY flashers will also work with LED bulbs.
    We offer some LED Flashers in our Tail/Brake Turn Signal Bulb category but we do not know which one (if any) will fit your vehicle. You will have to compare the pin-out of your flasher with the pin-outs of the flashers we offer, to see if we have a match, BEFORE you order one. Sorry but we do not have a flasher application list or the expertise to tell you which of our flashers will fit your vehicle.
    Another fix is the installation of Load Resistors which are wired across (in parallel with) the turn signal bulbs to simulate the load of a standard filament bulb. We also have these available in our car bulb shopping category.
  8. Mar 5, 2010 at 2:51 PM
    Viet2100
    Viet2100 Well-Known Member
    Viet
    South Florida
    2016 Prius 4T
    That's not the reason why manufacturers do not use LEDs as turn signals or reverse lights.
    They do this to save $, as stated above. They just did the brake lights because the split second you get with LEDs and their "instant on" might save a few accidents. If you look at more expensive vehicles, they are all switching to full LED tail lights (turn signals, brake and reverse).
  9. Mar 5, 2010 at 2:51 PM
    Viet2100
    Viet
    South Florida
    2016 Prius 4T
    I have a full LED tail light. It costed me $50 on top of the OEM LED tail lights, but it's well worth it.
