Need help with Turning off ABS, VSC, TRAC Mod
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Crf250rgeoffrey, Nov 20, 2014.
  1. Nov 20, 2014 at 3:28 PM
    Crf250rgeoffrey
    Crf250rgeoffrey [OP] KingGeoff
    Geoffrey
    San Bernardino
    2011 4x4 sport tacoma white long bed
    2.5 king shocks extended travel with adjusters Uniball uppers and lowers Extended brake lines Allpro leaf springs Toyo's 265/70/17
    I need help with the Turning off ABS, VSC, TRAC MOD !!!! I was going to do the ABS, VSC, TRAC MOD and don't understand what he doing he dose not explain it enough, if there any one that has done the mod and can explain the mod better please do so...(Pictures and Video will help too) This is the mod I am talking about below ......
    How many of you hate the ABS system in snow or while offroading on soft/loose terrain? I've had the ABS kick in so many times and almost make things worse on snow and gravel that I almost wish I didn't have it... Or at least had a way to turn it off...
    Thanks to a redneck working electrical magic with the USAF in Germany we have a solution! Thanks to Tacogrande on TN again!
    LOCKER MOD WRITEUP PAGE 2, VSC/ABS/TRAC/GOVERNOR MOD PAGE 3!
    This will only cost a you a new switch, enough wire to run from the ABS ECU to your switch, some zip ties, and some time.
    To Clarify some points here: Do NOT cut the wire! Splice into it for the ground! I used the ABS ECU (Passenger side, under hood) wire after talking to Tacogrande to clarify somethings (instead of the 4wd ECU wire I originally posted). I had cut the wires. Once they were reconnected, then grounded it worked.
    Here is the wire: (I cut it by mistake instead of using a quick splice, so ignore the shrink tape. It's around the blue w/yellow striped wire.)
    th_DSCF1855_044b1e955bdb87e85bcfdd4e4a37084b1f3190eb.jpg th_DSCF1856_3f594a4686711911ef185f62308390081314599b.jpg
    I sent the red wire for grounding it (thinner one, thicker one is for my 12v bed outlet) over to the driver side and through the grommet below. I zip tied it along the firewall to keep from touching the engine or exhaust.
    I used a blank switch next to the steering wheel and had to trim the hole slightly for my switch to fit. I used a switch with a cover to prevent accidentally turning the ABS off.
    th_DSCF1851_c8cee39559579808c3f81ac3131ad0b5e91014a3.jpg th_DSCF1848_e21ee0f7acf098a88566d6bd7361726774759cf6.jpg
    The blank was cut down with a dremel so that it was just a face plate to keep the switch from pushing too far into the dash. The hole is tight enough to firmly hold the switch. Just used a pocket knife to trim a little plastic until the switch would push in (took a bit of effort, but you want a tight fit).
    Note: This makes it THINK the locker is on so the locker and ABS lights are on. I tested it and it works. I don't have VSC (Vehicle Stability Control) or TRAC (Traction Control), but I'm told they are also turned off. Makes sense since all those get turned off when the locker is on, and this makes the truck think the locker is on (without triggering the actuator).
    More information below
    Traction Control (ATRAC hack) writeup! - Toyota Forums :: Toyota Nation
    Classic example of why you would want the ABS off..
    My ABS sucks & the locker rocks! - Toyota Forums :: Toyota Nation
    Edit:
    This has been more or less completely rewritten since I did it, got confused myself, had to clarify a few things with Tacogrande, and test to verify it works.
    aka ABS kill switch (for added search key words)
    You can also splice in at the 4WD ECU on Pin 20. This might help people with different colored wires.
    4WD ECU harness:
    4WD ECU above the glove box:
    Attached Thumbnails [​IMG] [​IMG]
  2. Nov 20, 2014 at 3:41 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    3percentneanderthal likes this.
  3. Nov 20, 2014 at 3:41 PM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    Hey, that's my 4wd ecu! (I'm tacogrande/tacosupreme) That was from almost ten years ago, I'm sure that link above is much better.
  4. Nov 20, 2014 at 3:45 PM
    Crf250rgeoffrey
    Geoffrey
    San Bernardino
    Thanks
    I just found it in the Mods and wanted to do it to my truck
  5. Nov 20, 2014 at 3:45 PM
    Crf250rgeoffrey
    Geoffrey
    San Bernardino
