Need help with u-joint replacement
Discussion in '1st Gen. Tacomas (1995-2004)' started by Chill65, Dec 3, 2016.
  1. Dec 3, 2016 at 6:41 AM
    Chill65
    Chill65 [OP] New Member
    Calvin
    2003 Silver Tacoma Prerunner
    None
    Hey All,
    Thanks for having me! Chill65 is having a fit trying to replace u-joints. Saw something on youtube about Toyota saying they were non-replaceable. But understand precision 280 joints will work but have to have minimal amount removed from outside surface. Anyone ever done this? Any help is greatly appreciated. Thanks!
    Chill65
  2. Dec 3, 2016 at 7:22 AM
    diabetiktaco
    diabetiktaco Instalander
    Eric
    New Jersey
    2022 GX460
    I've never known them to be non replaceable. If you are talking about opening the ear on the flange than no. I wouldn't do that because there's a very small chance it would still be round after you ground up up.
  3. Dec 3, 2016 at 7:36 AM
    Chill65
    Calvin
    None
    Diabetik81,
    Thanks for the reply! Not talking about opening the ear on the flange. Was talking about face of the joing where clip goes to keep it from walking. Would you by chance be familiar with removing joints from the cardan (think that's what it's called) assembly. It has two set of joints and hooks up to transmission. Any help will be appreciated. Thanks!
  4. Dec 3, 2016 at 8:24 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I think what you saw is 'Non-Servicable' - which means....they're sealed bearings. They don't have a grease zerk and can't be greased.
    As for the U-joint Caps.....AVOID pulling those off. Keep those on!! Why? There's a gazillion needle bearings in there that can and will spill out all over the floor if you take that cap off.
    Before pulling the driveshaft off - Mark the position of driveshaft to the diff. Make sure the ears of the shaft are matched up to the diff. It's hard to explain - but there's phasing/vibes that you can avoid by keeping it aligned as it was before.
  5. Dec 3, 2016 at 9:07 AM
    Chill65
    Calvin
    None
    Hey Janster,
    Been there with the needles in a prior life. Not a good place to be. Definitely did mark all of the rotatable parts prior to removal. Thanks for the reply!
    Janster likes this.
