need help with what size tires
Discussion in '2nd Gen. Tacomas (2005-2015)' started by HungarianDave, Dec 6, 2010.
  1. Dec 6, 2010 at 10:21 PM
    HungarianDave
    HungarianDave [OP] Well-Known Member
    2007 Toyota Tacoma TRD Off Road 4x4 v6 sr5
    hi guys i just got my tacoma and planning on doing this 3"lift to it http://www.roughcountry.com/toyota_4wd_tacoma_3.html what size tires could i put on with out rubbing and later on maybe a year or so i would upgrade the lift and tires but not for a while so thats why i wanna just do that 3" in lift first for just starters but no idea what size tires i can put on with out rubbing could you guys help me out?
  2. Dec 6, 2010 at 10:30 PM
    HungarianDave
    ok thanks man ;)
  3. Dec 6, 2010 at 10:52 PM
    acdronin
    acdronin Well-Known Member
    I just put 275/70/17 Goodyear Wrangler AT/S on mine with no lift, rub on hard turns and when suspension is compressed, front only. tiers barely clear suspension on the inside but it does ok. not sure how big u can go with a three inch lift but the main issue is tire width. i want to eventually put 315's on mine but it looks like 275's are probably as big as i can go in the front even with a lift. you'll have to look into getting rims with a different back-spacing or use wheel spacers.
  4. Dec 7, 2010 at 12:04 AM
    acdronin
    285/75r16s..they rub turning with 3" lift..
    Those are 16's right? I got 17's and the damn things are huge. I did see ta Taco with a three in suspension lift and 315's on 16's on after market rims.
  5. Dec 7, 2010 at 5:23 AM
    HungarianDave
    he said it ^
  6. Dec 7, 2010 at 5:49 AM
    Dilley
    Dilley Well-Known Member
    WA
    06 2.7L
    KN Cold air intake, Dynomax exaust, Husky liners
    I think you can you fit 285/75/16 with a bigger wheel offset with out any rubbing but what would that amount be?
  7. Dec 7, 2010 at 5:50 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    4.5" or less backspacing
  8. Dec 7, 2010 at 10:14 AM
    HungarianDave
  9. Dec 7, 2010 at 10:37 AM
    pngo121
    pngo121 Well-Known Member
    Phi
    Pittsburg, CA
    16' TRD Sport DCSB 4x4
    i have the 3" add a leaf lift on mines with 285/70/17 tires. i had to remove mud flaps and did a bit of cutting for it to no rub but i still get some occassional rub on hard turns hitting bumps.
  10. Dec 7, 2010 at 3:20 PM
    HungarianDave
    so would i be fine with 265/70s with that lift?
  11. Dec 7, 2010 at 3:35 PM
    jeremy.allen
    jeremy.allen Well-Known Member
    Jeremy
    The Ville, Ky
    07 DC, OR
    3" Lift with OME 885's, 5100's front and rear, alcan add-a-leaf. Banks Monster Exhaust, on the way: MM951C 17X9 and 285 MT/R's...
    ^^^Yes^^^
  12. Dec 7, 2010 at 4:30 PM
    HungarianDave
  13. Dec 7, 2010 at 5:05 PM
    cantac09
    cantac09 Official TW Igloo Builder
    Hugh Jass
    Saskatchewan
    tundra
    stock
    ya they will work but i would suggest that you get a different lift. i got a spacer lift before i was on here and it makes your truck ride like shit. since you're sticking with 265's you can get some billy 5100's that give 2.5 of lift in the front and get a aal for the rear and 2 more billy 5100's.
  14. Dec 7, 2010 at 5:33 PM
    Sigi
    Sigi Well-Known Member
    Sigi
    Sfv ca
    06 tacoma 4x4 trd offroad
  15. Dec 7, 2010 at 5:33 PM
    HungarianDave
    well how much are billy 5100's and what is an aal i'm all new to this and why is it better then a suspension lift?
  16. Dec 7, 2010 at 5:54 PM
    DdayIsNear
    DdayIsNear Well-Known Member
    Crazy
    NW Jersey
    TRD Offroad
    All pro sliders
  17. Dec 7, 2010 at 7:12 PM
    HungarianDave
  18. Dec 7, 2010 at 7:13 PM
    Snoyota
    Snoyota Well-Known Member
    Taylor
    Marin County, CA
    07 Black Dbl Cab Sport
    3" King coilovers with resi, king rear shocks with resi, ome dakar leafs, 4xinnovation kickout sliders, CBI front bumper, warn M8000 winch K&N filter. Pioneer deckplate with 500w alpine amp and 13" Focal Sub
    35x12.5 M/Ts
  19. Dec 7, 2010 at 9:57 PM
    HungarianDave
  20. Dec 7, 2010 at 10:09 PM
    cantac09
    Hugh Jass
    Saskatchewan
    tundra
    stock
    get the first one. the last 2 are spacer lifts and you dont want those, trust me. the first one has lift coils and a small top plate spacer which gives you the full 3 inches of lift and an aal is an add-a-leaf which gives you lift in the back.
