Need help with wires
Discussion in '4 Cylinder' started by silverback, Feb 11, 2010.
  1. Feb 11, 2010 at 1:56 PM
    silverback
    silverback [OP] Well-Known Member
    central CA
    2006 Prerunner SR5
    painted door handles, bilstein 5100's front and back, K&N air filter. Precision power component speakers and Kenwood deck.
    I have been searching for hours on some spark plug wires for a 2006 reg cab prerunner 2.7 . The only thing that keeps popping up are the Mallory or the accel, or Taylor . Those are all north of 100 bucks. Im just looking for some factory replacement wires. Anyone with a site that could help Id appreciate it.
  2. Feb 11, 2010 at 2:44 PM
    neslerrah
    neslerrah Taco lovin'
    Harrelsen
    Tucson
    5 lug BEAST!
    Secondary air filter removed, elbow mod, BFG T/A KO (31x10.5R15), 15" American Racing Mojaves, BHLM, Dome Light MOD (Blue), Pioneer headunit, Sockmonkey 'TACOMA' Decals, Readylift 5-lug SST, Rear Shocks - Bilstein TRD, Dynomax Super Turbo #17748, DDM Slim Ballast HID Kit H4 Hi/Lo -35W 6000K in headlights, Apexcone Raptor HID Kit H3 - 35W 6000K in Hella 500s, aFe CAI #51-10762, WeatherTech Floorliner, 200W Smart AC Inverter
  3. Feb 11, 2010 at 6:14 PM
    rs50fox
    rs50fox Active Member
    USA
    The 2006 2.7 has the coil mounted on the wire(coil-over plug) not the older cars, I think. What makes you think they need to be replaced?
  4. Feb 12, 2010 at 11:36 AM
    silverback
    central CA
    2006 Prerunner SR5
    well to be honest I bought the truck a few months ago with 53k miles on it and looking to do a good tune up on it. Not really sure if they need to be replaced but figures since Im replacing plugs and all . Now that you got me thinking if they are fine I wont replace them. I did look at Rockauto.com and that is where most of what I found was Mallory or taylor etc. I mean I'll go that route if it helps with better ignition.
  5. Feb 12, 2010 at 12:11 PM
    uood8
    uood8 If You Search...You Shall Find.
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    there are no spark plug wires, the coil pack sits on top of the plugs. and the plugs don't call for replacing till after 100k miles. they are titaninum tipped or something.
  6. Feb 12, 2010 at 3:28 PM
    silverback
    central CA
    2006 Prerunner SR5
    jesus I look stupid. If it werent for you guys here I would get screwed left and right on my ignorance. Beers in the mail.
  7. Feb 12, 2010 at 5:52 PM
    uood8
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
  8. Feb 15, 2010 at 9:58 AM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    Got 45k miles on my 2006 2.7 and I'm thinking about pulling the plugs just to see what they look like (running condition), and to make sure they used enough anti-seize at the factory. :)
  9. Feb 15, 2010 at 4:21 PM
    TimS
    TimS Well-Known Member
    Tim
    Maine
    2010 DC tacoma/2005 access cab
    Rebuilt with flatbed 5100's, new spring packs
    Not a bad idea to pull them even if they don't need to be replaced. Just so you know they will come out. Also, take your rear drum brake off for the same reason. I've had some tough moments on both with pass vehicles. You don't want the stuff seized or rusted on.
