NEED HELP WITH WIRING AUXILARY LIGHTS
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sooner, Oct 14, 2011.
  1. Oct 14, 2011 at 8:49 PM
    sooner
    sooner [OP] Well-Known Member
    TX
    2011-4X4-LONGBED
    6-inch pro-comp lift-,n-fab 6 step nerfbars,extang touneau cover,go rhino grille guard,aftermarket fogs,3.5 driving lights,7-inch off road lights.pro comp skid plate,train horns,reese tow hitch,escort 9500ix,blend mount wireless radar mount.avs bug deflector and window vents,5%window tint.28-led back up lamps,sock monkey 3rd brake light decal,magna flow exhaust.klein train horns.nitro,nitro 4.56 gears,pro-comp traction bars,volant super scoop air intake.
    i installed a new grill guard and mounted 2 different sets of lights.lights are mounted and tied in up to engine compartment.i have 2 separate 4-pin relays and am running straight to battery,both of my switches have 2 prongs any help would be greatly appreciated.
  2. Oct 14, 2011 at 9:18 PM
    wmdpowell
    wmdpowell Well-Known Member
    Bill
    Selkirk, NY
    4x4 reg cab, 5 speed
    Better tires Hurcules Terra Track, trimmed front mud flaps, (access limited tonneau-took off) softopper, ats running boards, Piaa fogs, window vents, Wireless thermometer, extra bed rings, valley hitch
    Much good info here on installing lights. I am waiting on some fogs I ordered and have found some detailed posts on wiring in general and specfic.
  3. Oct 14, 2011 at 11:53 PM
    sooner
    TX
    2011-4X4-LONGBED
    thanks
  4. Oct 15, 2011 at 12:12 AM
    4Wheelin4Banger
    4Wheelin4Banger Longtime Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Silver State Edition
    3" OME lift 885s & Dakars riding on 33" KM2s Click the sig pic to see the build thread .
    Some good pics and what to do in My Auto OEM Fog Light Mod.
    Relay pin 86 is where you want to attach the switch. One leg of switch to 86 and the other to a power source. I skipped the switch and used the running lights for the power source. Any time my running lights are on so are my fogs. Hope it helps, also links to other methods in my Mod.
