Need help with Wiring/Math Hellas & LED's
Discussion in 'Lighting' started by Baoser, Mar 29, 2013.
  1. Mar 29, 2013 at 11:01 AM
    Baoser
    Baoser [OP] Well-Known Member
    George
    Pittsburg, CA
    2012 DCSB Offroad
    So this may be a stupid questions but here goes...
    I recently got a plate bumper and the stock fogs were replaced with Blitzpro 3inch LED pods.
    Also have some 7inch Hellas with HID's.
    So...
    The LED's are 12Watt and the HID's are 35Watt.
    So according to the internet A=W/V so the total of both units Amp draw is
    A= 12/12
    A= 35/12
    Which comes to ~3.91 Amps (Someone please correct me if I am wrong)
    If I were to hook up both light systems to the stock wiring harness/OEM fog switch would everything work fine? Will I melt wires?
    I do plan on adding a HID harness soon, just don't have one yet.
    Or what would be the best way to hookup both sets to a single switch with minimal additional wiring? I am ok with running electrical stuff, but was never too good with calculating what fuses/relays I need... Thanks in advance hope it makes sense to someone who can help.
    Also these will obviously not be on all the time, but will be put to use at night/dark areas.
  2. Mar 29, 2013 at 11:08 AM
    llibrm
    llibrm OH NOOOOOO!
    Bill
    Winthrop, WA &Convection Oven, AZ
    06 DCSB, 06 LC120 (sold)
    Pelfreybilt Aluminum Bumper, KING 2.5 on all four corners, 4x4 illuminated switch, Cobra 75 w/ 3' Firestick, 2M/ 70cm Radio w/ Diamond NR770HB, Pelfreybilt bed bar, Lightforce Stiker 170s, BD 20" OnX6, BD S2 ditch lites on SDHQ mounts, BD SAE Fogs
    I'm not sure of actual numbers, but the reason HIDs require a harness is because of the inrush when they are warming up. Once up to temp, they draw a small amount of current. That's the number you need to factor into your amperage being placed on factory wires.
  3. Mar 29, 2013 at 11:14 AM
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    12W + 35W = 47W
    47W * 2 = 94W = 7.8333 Amps
    I'm running a pair of 55W H10 bulbs in my stock fogs with no problems
    55W * 2 = 110W = 9.1666 Amps
  4. Mar 29, 2013 at 11:15 AM
    Baoser
    George
    Pittsburg, CA
    2012 DCSB Offroad
    Doh forgot to time by 2 haha thanks
