Need help
Discussion in 'Toytec Lifts' started by beartrack, Feb 16, 2011.
  1. Feb 16, 2011 at 3:53 AM
    beartrack
    beartrack [OP] Well-Known Member
    Nova Scotia
    SR5
    toytec coilovers, 2"aal's, LR UCA's hood struts, weather tech mats
    I bought the toytec lift and need to know how far to turn the adjuster up inorder to get 3" of lift. I also have a half inch top plate and was wondering if I should bother using them or just go with the coilovers. Thanks for any help
  2. Feb 16, 2011 at 1:59 PM
    Toytec Lifts
    Toytec Lifts Toyota Suspension specialist Vendor
    Rocky Mountains
    Toyota's are awesome
    Just use the coilovers and leave the top plate spacers out. There isn't a exact adjustment for 3 inchs of lift on the coilover since every vehicle will have a slightly different weight which will affect the lift height. They are preset to ~2.5 inches of lift. The only accurate way to ensure you get 3 inches of lift is to measure the height of the truck before you install the lift and compare it to the measurement after you install.
  3. Feb 16, 2011 at 3:17 PM
    beartrack
    Nova Scotia
    SR5
    Thanks for the reply Dylan. When you preset them for 2.5" how much thread is showing on the bottom. That will give me a starting point.
