NEED HELP!!!!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by fish1284, Feb 21, 2011.
  1. Feb 21, 2011 at 4:44 PM
    fish1284
    fish1284 [OP] Member
    cassey
    winter garden
    toyota tacoma
    CHANGED OIL, PUT NEW OIL IN, WENT TO CRANK AND NO START there was a clunk and now it looks like the lights on the dash like the check engine,battery,oil exc. are dem and the dome light is dem, BATTERIES GOOD,BUT LIGHTS DEM AND FLICKERING,ALTERNATER GOOD ANY SUGGESTIONS, PLEASE HELP.
  2. Feb 21, 2011 at 5:58 PM
    fish1284
    cassey
    winter garden
    toyota tacoma
    please anyone!!!!i need help bad
  3. Feb 21, 2011 at 5:59 PM
    04LTtacoma
    04LTtacoma Well-Known Member
    Outer Space
    Call TOYOTA!
  4. Feb 21, 2011 at 6:00 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    What year of vehicle? Engine?
  5. Feb 21, 2011 at 6:01 PM
    fish1284
    cassey
    winter garden
    toyota tacoma
    04 3.4
  6. Feb 21, 2011 at 6:02 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Hows the battery cables look? Are the terminals clean, and the cables tight?
  7. Feb 21, 2011 at 6:03 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    Are you sure the battery is good? Did you get it tested? Otherwise you might have a bad starter. You might try banging on it with a hammer and see if that helps. Also check your connections at the battery, just because your battery is good doesn't mean it's sending enough power to the starter.
  8. Feb 21, 2011 at 6:04 PM
    cc350
    cc350 Retired Member
    Bad connection at battery? Bad ground? + to starter bad or loose?
  9. Feb 21, 2011 at 6:07 PM
    The1youluv2hate
    The1youluv2hate Well-Known Member
    Peps
    SP... CaL
    11 TRD sPort
    5100's@1.75 Horns (Andres) Satoshi TRD cat back BHLM
    Did u accidentally drain ur tranny fluid ...
    Did put correct oil in
    Did u call pick ur parts
  10. Feb 21, 2011 at 6:08 PM
    fish1284
    cassey
    winter garden
    toyota tacoma
    yes it was starting fine then after changing oil went to go start and it was like the engine locked up but its not cause i turned the motor over by the crank pully but now my dash lights are dem and my dome light is dem and now when i try to start it it clicks like the battery is dead but its not!!!!
  11. Feb 21, 2011 at 6:10 PM
    The1youluv2hate
    Peps
    SP... CaL
    11 TRD sPort
    Sounds like u need a new battery or starter
  12. Feb 21, 2011 at 6:11 PM
    The1youluv2hate
    Peps
    SP... CaL
    11 TRD sPort
    Also did u push the clutch in
  13. Feb 21, 2011 at 6:17 PM
    fish1284
    cassey
    winter garden
    toyota tacoma
    it's an automatic
  14. Feb 21, 2011 at 6:49 PM
    NelsonTacoma
    Tucson, AZ
    Are you sure the battery is good? How many CCA's is it currently putting out? How many volt's does it have? In all my experience if the starter clicks you usually aren't getting enough power to the starter to turn it over.
  15. Feb 21, 2011 at 6:54 PM
    Demon Taco
    Demon Taco Well-Known Member
    Robert
    New Hampshire
    Gold Tacoma SR5 4X4
    check your ground and positive battery cables at the battery and then at the starter.by checking i mean remove them and wire brush them and replace them and retighten.
  16. Feb 21, 2011 at 7:09 PM
    subtleshift
    subtleshift Noob
    Dallas
    Irvine, Ca
    01 Tacoma TRD
    K&N high flow filter, 2x Yakima bike mounts
    too much oil?
  17. Feb 21, 2011 at 7:17 PM
    fish1284
    cassey
    winter garden
    toyota tacoma
    no not to much oil i put 5.5qts
  18. Feb 21, 2011 at 7:20 PM
    The1youluv2hate
    Peps
    SP... CaL
    11 TRD sPort
    Check ur fuses ..
    But I'm gonna say it's. Ur starter or battery (get yellow top)
  19. Feb 21, 2011 at 7:25 PM
    NelsonTacoma
    Tucson, AZ
    I guess he's not gonna answer any of our questions........
  20. Feb 21, 2011 at 7:42 PM
    The1youluv2hate
    Peps
    SP... CaL
    11 TRD sPort
    Maybe he's working on the truck
