NEED HELP!!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by Mxer256, Jan 28, 2012.
  1. Jan 28, 2012 at 11:59 AM
    Mxer256
    Mxer256 [OP] Well-Known Member
    Tyler
    Mississippi
    2012 Prerunner
    2012 Tacoma Trd sport, 10" bulletproof lift with traction bars and icon resi rear shocks, custom headlights and tail lights, 24x14 American force jades,37x13.50x24 Toyo mt, 1" borla wheel spacers, 30" lightbar, new build so more to come come
    So yesterday i put leds in my daytime running lights. Last night when i went to turn my interior lights on they didnt turn on. I went to autozone and no one new what it was....ive checked all of my fuses but is it possible its a relay? I tried the power outlet relay and it wasnt that...My daytime running lights and my interior lights do not work....what could it be? anyone ever have this problem before?
  2. Jan 28, 2012 at 12:01 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    I've never heard of that before... sorry op.
    next time though, try to stay away from "help" as a thread title, you're not going to get the attention you want.
    but bump for an answer
  3. Jan 28, 2012 at 12:01 PM
    TacoDawgfan
    TacoDawgfan Hunker Down You Hairy Dawg!
    Georgia
    2011 Silver 4x4 TRD Sport w/JBL
    5100's at 1.75, Rear leaf TSB, Moto Metal 951 16x8, BFG TKO2 265/75/16, AFe Stage 2 CAI w/pro dry filter, Kenwood DDX374BT installed with Idatalink Maestro kit, Access Loredo tonneau cover, N-Fab steps, Tinted windows, EGR in channel vent visors, UGA drink coasters in the front cup holders, and a Graco car seat in the back seat
    I have no clue, hopefully someone will chime in that can help you.
  4. Jan 28, 2012 at 12:02 PM
    Mxer256
    Tyler
    Mississippi
    2012 Prerunner
  5. Jan 28, 2012 at 12:03 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    try switching the normal bulbs back in?
  6. Jan 28, 2012 at 12:04 PM
    Mxer256
    Tyler
    Mississippi
    2012 Prerunner
    Tried that...and none of my interior lights work when i turn them on...went to two shops and they were like maybe its your headlight fuse haha
  7. Jan 28, 2012 at 12:39 PM
    JSFoster75
    JSFoster75 Well-Known Member
    Scott
    Bluff City, TN
    2018 Wrangler JLU Sahara
    Too many to list.
    Not sure about Toyota's, but I've seen trucks with fuses that control things they aren't supposed to control... Try pulling out each fuse one at a time and checking them, could be that it's either double-fused, or mislabeled in the manual... Seen stranger things... Make sure to double-check all connections to make sure they are connected correctly!
    Also, check to make sure they are grounded... A electrical meter is a wonderful thing to own and know how to use...
    Another thing, did you have the lights working at any time during the installation?
  8. Jan 28, 2012 at 1:01 PM
    joes06tacoma
    Joe
    Central Coast, CA
    X2 on the fuses.
    You say you put LEDs in the daytime running lights? I thought first gens used the low beams as DRLs? Are you talking about the parking lights that come on at the first position on your headlight switch? Those would probably be under the taillight fuse.
  9. Jan 28, 2012 at 3:54 PM
    Mxer256
    Tyler
    Mississippi
    2012 Prerunner
    like the corner lights... and yeah ive checked every fuse
  10. Jan 28, 2012 at 6:11 PM
    joes06tacoma
    Joe
    Central Coast, CA
    This should be the relevant wiring diagram.
    The way I interpret this, there should be a 120A "alternator" fuse/fusible link, a "taillight" relay, and a "taillight" fuse in the fuse/relay box under the hood. The relay is activated by the body computer when you turn on the light switch.
    Recheck the ten amp taillight fuse under the hood and make sure the 120A alternator fuse is good. If the light switch, 120A fuse, and relay are all okay, you should have power present at the ten amp taillight fuse when the light switch is turned on. In other words, even if the fuse is okay, it might not be getting power. Find out if there is power at that fuse and then you can work backwards to find the problem.
    But I am still suspicious that this is just a fuse that is bad. Maybe it still LOOKS okay but is blown.
    Someone else already suggested you should own a multimeter or test light. I agree. Best 20 bucks I've ever spent on vehicle related tools.
