Need help
Discussion in 'Technical Chat' started by cfid67, Feb 6, 2013.
  1. Feb 6, 2013 at 2:28 PM
    cfid67
    cfid67 [OP] Member
    cape cod
    10 Tacoma sr5 trd sport dc
    Help sorry for being a newbie but I was doing the fog light mod today on my 2010 taco and couldn't seem to get it to work did anyone have a problem with the quick splice I don't think mine actually made a splice either that or I have a bad connection can someone help please thanks in advance
  2. Mar 6, 2013 at 6:18 PM
    KEGCUP
    KEGCUP New Member
    Jeffrey
    Ventura County
    05 TRD Off Road Tacoma
    air intake Icon coil overs Total Chaos UCA
    When I first tried the splice it did not work on my 2005. Then I went back spliced back the wire cover and then tried the splice again. The second time it worked....make sure that the crimp is good on the fog relay also.
    My problem is I may have blown a fuse, because now my rear running lights do not work...suggestions, comments???
  3. Mar 6, 2013 at 6:20 PM
    Jeffvt0508
    Jeffvt0508 Well-Known Member
    Jeff
    Columbia, SC
    2015 DCSB 4x4 trd offroad
    Ome 885, dakars, lr uca, bed bars sos sliders
    make sure the fog light button is pressed "on" then disconnect reconnect battery
  4. Mar 6, 2013 at 7:01 PM
    KEGCUP
    KEGCUP New Member
    Jeffrey
    Ventura County
    Tried disconnecting the battery with the fog lights in the on position. Left battery disconnected for about 30 seconds and then connected. Tried the lights again, but still no running lights. All the other lights work too...? Changed a fuse that seemed fine and put in place of, at the running light fuse, still no dice. Very frustrating...
