Need help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Gregory28, Nov 23, 2016.
  1. Nov 23, 2016 at 11:20 PM
    TacomaTrav
    TacomaTrav Well-Known Member
    Travis
    07' Tacoma SR5, 4.0L 6spd, ELocker
    NONE
    To each their own, not trying to be a dick, my mind just doesn't work that way....make that Taco your own brother!!!
  2. Nov 23, 2016 at 11:25 PM
    Gregory28
    Gregory28 [OP] Member
    Greg
    07 reg cab Toyota Tacoma
    Right now 3 inch lift 3 inch body lift but I am going to put 6 inch lift on later
    Thank you all
  3. Nov 23, 2016 at 11:25 PM
    Pigpen
    Dan
    Northwest Montana
    My buddy has a 6" DB with 35s. He has a Bruteforce bumper and aftermarket fender flares. The tires are Toyo MTs on 17s. It looks great and serves his purposes. You'll love it, OP.
    Gregory28[OP] likes this.
  4. Nov 23, 2016 at 11:30 PM
    Gregory28
    Greg
    Yes
  5. Nov 23, 2016 at 11:49 PM
    TacomaTrav
    Travis
    NONE
    Are you going to regear with the bigger tires?
  6. Nov 24, 2016 at 12:13 AM
    Gregory28
    Greg
    I'm going to see how it does and if need to I will
