Need help
Discussion in 'Suspension' started by DaltonT89, Jan 14, 2019.
  1. Jan 14, 2019 at 1:15 PM
    DaltonT89
    DaltonT89 [OP] Member
    William
    2018 Toyota Tacoma TRD off road
    Hi quick question will a 285/75R17 or 295/70r17 tire fit on my 2018 TRD off road Tacoma with a stage 4 2.75” icon lift without having to do a CMC or should I just do the 285/70
  2. Jan 14, 2019 at 1:21 PM
    SumAznGuy210
    SumAznGuy210 Well-Known Member
    Sam
    2018 Cement TRD Off Road
    Check out @runnin4tacos YouTube channel. Search tacotwonz, he has the 285/75/17. He did CMC and pinch if I’m not mistaken.
    Subd though since i want the same thing on my truck!
    runnin4tacos likes this.
  3. Jan 14, 2019 at 1:27 PM
    DaltonT89
    William
    Yeah I’m set n the 285/70 or the 295 and I’ll definitely check it out thank you For the into.
  4. Jan 14, 2019 at 1:30 PM
    tcjacado
    tcjacado Well-Known Member
    You are going to need to cut that can mount.
  5. Jan 14, 2019 at 1:34 PM
    DaltonT89
    William
    Is doing a cmc a big deal. I just don’t know if it’s worth it. I would hate to cut a brand new truck.
  6. Jan 14, 2019 at 1:37 PM
    tcjacado
    No it's not a big deal.... has been debated quite often here. Most that have done it, you cant even tell it's there unless you are looking for it. It doesn't affect the crash rating as it still does what it was supposed to by deflecting the tire away from entering the cab via the floor/firewall.
  7. Jan 14, 2019 at 3:45 PM
    DaltonT89
    William
    Ok that’s good to know and I really appreciate the info and one last question. Is it pretty expensive if I have a shop do the cmc
  8. Jan 14, 2019 at 3:52 PM
    Wolftaco0503
    Wolftaco0503 Well-Known Member
    Adam
    Chicago
    2013 Super White LONG BED TRD SPORT 4x4
    Maglite mod Bottle Opener in bed Weathertech Mats Front & Back
    Please change the topic to something more descriptive please. We like to keep the NEED HELP to those people that are stuck our lost on a trial.
    TACORIDER likes this.
  9. Jan 14, 2019 at 4:07 PM
    DaltonT89
    William
    It won’t let me edit the topic.
  10. Jan 14, 2019 at 4:30 PM
    Wolftaco0503
    Adam
    Chicago
    1. Go to edit post
    2. Top right corner you will see a line of text that says EDIT TITLE
  11. Jan 14, 2019 at 7:52 PM
    tcjacado
    No it should be about 100 to 150 bucks including the plates.
  12. Jan 15, 2019 at 3:50 AM
    DaltonT89
    William
    That’s not as bad as I thought thank you very much
  13. Jan 15, 2019 at 9:11 AM
    Wolftaco0503
    Adam
    Chicago
    anytime so do you want to use this new found information?
