Need help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ta2010, May 4, 2020.
  1. May 4, 2020 at 1:36 PM
    ta2010
    ta2010 [OP] Member
    2010 black Tacoma 4dx2
    Hi everyone hope everybody is doing ok with this nightmare.
    ok enough of that i have a real problem hopefuly you can help.
    the problem is when i start up my tacoma i turn the key and nothing happens it's like a battery drain than i turn the key again and it starts. i had the battery and alternator check everything ok. so what could be the problem and has anyone had this problem.
    Biscuits likes this.
  2. May 4, 2020 at 1:41 PM
    ryfox0276
    ryfox0276 Well-Known Member
    Montana
    2013 RC 4x4
    Nothing at all happens when you turn the key the first time? No noises/ lights/ starter? Then it starts up normal the second time?
    It could be your starter, but it sounds like there could be deeper electrical issues. Need more info.
    wilcam47 likes this.
  3. May 4, 2020 at 4:29 PM
    jproffer
    jproffer Well-Known Member
    Jim
    Perryville, MO
    '15 MGM Sport DCLB, V6
    First guess out of my amateur mind is a failing P/N switch, but I agree...need more details. Does it do this every single time you want to start it, without fail....100% of the time?
    Also wonder if it's not going fully into park. Our work trucks do that pretty regularly...dirt gets in the linkage and it wont go all the way in. If you think about it sometime, before trying it the first time, put it in neutral instead of park.
  4. May 4, 2020 at 6:01 PM
    Gen2 Man
    Gen2 Man Well-Known Member
    Midwest
    07 Sport DCLB
    3rd Gen Sport wheels
    There was a factory service bulletin for earlier trucks I wonder if yours is included.
  5. May 4, 2020 at 7:02 PM
    pdaddy
    pdaddy WeLl-KnOwN mEmBeR
    Preston
    Central AL
    ‘13 DCSB Converted Prerunner 4wd
    Sorry to be a thread nazi but using “help” in your title is generally frowned upon and used for people who are stranded on a trail or somewhere. Might want to change it
  6. May 4, 2020 at 7:04 PM
    Dan 77
    Dan 77 I leave my bikes outside
    Dan
    San Antonio
    06 DCSB TRD Sport 4X4
    Kings and TC UCAS 01 DCSB 4X4 Totaled All-Pro bumper, mile marker winch
    Maybe he is stranded somewhere and his truck doesn't start? :notsure:
  7. May 4, 2020 at 7:12 PM
    rphillips
    rphillips Well-Known Member
    Rick
    Norene TN.
    2013 Reg. cab 4x4
    none
    If a MT the clutch has got to be on the floor fro it to start, Oh wait, if it is an auto. it must be completely in park. And I guess the Taco's still have starter solenoids. Shoot, I don't know what is going on.
  8. May 4, 2020 at 7:19 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Listen carefully when you turn the key and nothing happens. If you hear a very small click then nothing I would almost bet money that the starter solenoid is in need of a repair kit. Cheap fix.
    You can buy the contacts and plunger new from Nations Starter and Alternator for about 30 - 35 bucks. Much cheaper than hundreds for a rebuilt POS from Autozone etc.
    https://www.nationsstarteralternator.com/Starter-Rebuild-Kits-s/37.htm
    Check this video for rebuilding the solenoid on the starter.
    https://www.youtube.com/watch?time_continue=2&v=qwokxzjlYcQ&feature=emb_logo
