Need help!
Discussion in '1st Gen. Tacomas (1995-2004)' started by Logun40, May 19, 2024.
  1. May 19, 2024 at 1:27 PM
    Logun40
    Logun40 [OP] New Member
    Toyota 4Runner 3.4l swapped
    I have a 91 4Runner with a 2002 3.4l Tacoma engine swap and last week I was on my way home from work and it threw a CEL and had a huge loss of power and a popping noise coming from under the passenger side engine bay. I went to start it the day after it and started twice but barely ran now it won’t turn over anyone know what’s going on? My diagnostic port isn’t working so I can see what code it’s throwing. I’d appreciate any help.
    Bivouac likes this.
  2. May 19, 2024 at 1:36 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Time to figure out why you can not pull codes.
    Other wise we are all guessing.
    You could pull the engine and tare it down.
    Did the engine start knocking did you spin a bearing?
    It cranks with no strange noises ?
    wilcam47 and Logun40[QUOTED][OP] like this.
  3. May 19, 2024 at 2:24 PM
    Logun40
    I’m currently trying to figure out why I can’t pull codes and was just posting this incase anyone had any ideas where to start. No knocking or weird sounds and still had power at low rpms just when I went to accelerate it bogged down then threw on the CEL. And yes it cranks with no strange noises at all.
  4. May 20, 2024 at 5:52 AM
    Bivouac
    I would look at your ECM ground it might have worked loose causing all sorts of problems.
    Losing any of the sensor signals could cause fuel to be shut off . To what the ECM thinks is a non running engine.
    Noises can be real tricky . Did a O2 sensor vibrate loose hence the popping noise . Leaking cross over pipe/ Your exhaust is on the left side ??
    Finding why the OBD II system is down is your first step unless something is very easy to spot.
    Good luck!
