Need Ideas for attaching tow shackles to front end.
Discussion in '1st Gen. Tacomas (1995-2004)' started by brs127s, Oct 8, 2011.
  1. Oct 8, 2011 at 11:34 PM
    brs127s
    brs127s [OP] Well-Known Member
    O'Fallon, MO
    04 D-Cab 4x4 Limited TRD
    TRD Headers, Aero Turbine AT2525XL Deckplate Mod, TRD tranny cooler, King Coilovers, LR UCAs, Alcan 5 Leaf springs and Bilstein 5100s, Shrockworks front bumper, CBI rear bumper.
    I need some ideas. I have a brush guard and factory skid plates on my D-cab. The brush guard uses the two bolts that go up through the bottom of the frame for the tow hook on the passenger side and through the frame on the driver side. The problem is, on the driver side, one of the nuts that is welded inside the frame came loose. A buddy helped me drill and tap the frame to accept a bigger bolt. This is fine for my current set up, but I would like to make and attach some tow shackles to the frame. Everything I have seen online uses the bolts I am currently using. I am afraid of using them now, as the bolt that is threaded through the frame doesn't have enough threads to hold a tow shackle. Has anyone ran into this problem before?
    I have considered welding some 1/4" thick angle iron to the frame, drill it, and tap the holes. This is give me some good threads. What other options are there?
  2. Oct 10, 2011 at 11:56 AM
    brs127s
    O'Fallon, MO
    bump--anyone?
  3. Oct 10, 2011 at 11:57 AM
    Brunes
    Brunes abides.
    Rotorhead
    Get rid of the damage multiplier-i mean brush guard- and get an offroad bumper meant for winching/recovery??
  4. Oct 10, 2011 at 1:12 PM
    brs127s
    O'Fallon, MO
    Even with an off-road bumper, don't they bolt to the frame in the same locations I am having issues with?
    As for the brush guard, it may be a damage multiplier, but it has prevented my truck from being totaled when hitting deer. I realize it isn't ideal for wheeling/recovery, but it (I should say they, as I am on guard #3) has served its purpose.
  5. Oct 10, 2011 at 8:24 PM
    STLharry
    STLharry Lube: It's the key to penetration.
    Harry
    VT
    Yeti Rescue Package with 270k miles
    '95-'97 camouflaged, ARB bull bar, RAT Products skid plate kit, sliders, Green Mountain Customs rear tube bumper and overland bed rack, King coilovers with Icon neoprene covers, defenestrated sway bar, OME Rear Suspension: CS046R leafs + AAL/5125 shocks/NWOR greasable hardware/U-bolt flip kit; S13WL Tundra calipers/pads/rotors, IPF H4 lenses and bulbs, IPF 968 DCG 100W lights, clapped out CB radio, Aussie-spec FJ60 inclinometer, ARB CKMA12 compressor, Superwinch S9000 with 12V Guy clock switch, 4' Hi-Lift, deckplate mod/grey wire mod/dif breather extensions, Duratrac tires, Sockmonkey bedside decals, boat cupholder, Dakine bike pad
    This.
    Get rid of the flimsy piece of metal and get some real protection (Elite or ARB are my favourite). You'll end up paying less in the end if you get in an accident.
    You can also use them for recovery (or being recovered...hah) and not worry about endangering your truck. I have 2 4T shackles on my ARB and I have used them countless times in the past 2 years.
    Sorry we can't be helpful in the way you're asking...but a lot of TW members really care about their trucks and therefore don't skimp on costs when it comes to modifications (see: Body Lifts, Spacers, etc).
  6. Oct 10, 2011 at 8:46 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    This ^^^ This VVV :cool:
  7. Oct 10, 2011 at 10:47 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    ^^^ seconded! I went from a brush guard to this.
    rjbiii likes this.
  8. Oct 11, 2011 at 6:43 AM
    brs127s
    O'Fallon, MO
    Okay guys, I understand an aftermarket bumper is the best route to go. My problem is knowing if I can mount one up due to issues with factory attach points.
    I was looking at the instructions for ARB and Elite, but would like someone to verify what I read. If I read it right, you remove the crush cans from the front of the frame and replace them with a bracket from ARB (Elite threads a bolt where the crush cans were). What do you do with the existing holes/welded nuts on the underside of the frame? I am referring to the 2 bolts on each side of the underside of the frame. On the right side, they bolt the factory tow hook to the frame. The left side does not have anything, and uses shorter bolts.
    This is where I have a problem. One of those nuts broke loose inside the frame and we just threaded the frame hole itself. If I have to reuse the threaded frame hole, it is not a good attach point for anything, including an aftermarket bumper. If I need to attach to these bolts, would I be better off drilling through the top side of the frame and running bolts all the way through the frame, or should I just weld some thick steel to the bottom side of the frame and thread it?
  9. Oct 11, 2011 at 7:18 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    For the Elite bumper those are more mounting points. So you would end up with 5 on each side. If just one bolt is screwed up i doubt it'll be a problem.
  10. Oct 11, 2011 at 8:24 AM
    CalgaryRider
    CalgaryRider Well-Known Member
    Shayne
    Cranbrook, BC
    09 Access Cab SR5
    2009 Tacoma SR5 Too many to list, but its a SR5 with a TRD Sport Heart
    I went from this:
    to this!
    Honestly on a brush guard there are no good mounting points, the metal is flimsy, and bends or breaks (yes they might help occasionally on the trail but go for a steel bumper)
    The only real anchor point on the front is the tow loop on the driver side. The tie down on the passenger side of the frame is not designed for any type of tugging.
    For bumpers it comes down to what your personal preference is, look around, find what you like and then add it to the truck!
  11. Oct 11, 2011 at 11:14 AM
    UndefinedTaco
    UndefinedTaco I'll eat all your food.
    Justin
    Tracy, CA
    Toyota
    It's an 89 Toyota Pickup. I got some stuff done to it.. FJ axles going under it soon.
  12. Oct 11, 2011 at 6:15 PM
    STLharry
    Harry
    VT
    My old truck had that issue too when I went to install my ARB bar. The nut on one side inside the frame broke loose. I just cut the frame end off to get to it and welded the shit out of it and it was all good. So that is one way to get it to work.
  13. Oct 11, 2011 at 6:31 PM
    austinstaco
    austinstaco Well-Known Member
    Austin
    Dallas TX
    06 PreRunner
    to many
    I welded these 15000 lb d-rings from attwoods.
