Need ideas on fishing rod holder for truck
Discussion in '1st Gen. Tacomas (1995-2004)' started by txtoytaco, Jul 27, 2015.
  1. Jul 27, 2015 at 2:01 PM
    txtoytaco
    txtoytaco [OP] Member
    Tacoma
    Any good ideas to mount fishing rod holder in back of truck and where?
    There is the 3 holder plastic one at academy - guess bolt in truck by back window - left - center - right side?
    Any other ideas?
  2. Jul 27, 2015 at 2:02 PM
    la0d0g
    running for the hills
    For crawling not hauling
  3. Jul 27, 2015 at 2:12 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    you can make your own easy enough, just use pvc "tees" for the cross bar and with a 12" length of pipe sticking up for the pole to sit in.
    make as many rod holders as you need, then just secure it to the truck with clamps or brackets and its a good idea to have a bunge cord to keep them in place
  4. Jul 27, 2015 at 4:23 PM
    la0d0g
    Ah yes, totally missed the fact that this is in the 1st gen section. As you were :D
  5. Jul 27, 2015 at 5:29 PM
    keakar
    karl
    louisiana
    for the cross bar use pipe clamps, for the angle you want just use a 90 on the ends and angle it at the correct angle with a 12" pipe in them as "support legs" then once its all sitting just how you like it mark all the fittings and pipe, take it apart and glue them together. then clamp those "support legs" to the bed and its not moving and stays at the angle you want it.
    the design is endlessly changeable as you will see so you can figure out the best support for how you want it, you might want it to sit on top of the bed and use tees near the bed rails for supports going straight down to clamp against the front wall of the bed to keep the floor free. the possabilities are endless and pvc pipe is cheap but the fittings are like $2-$3 each so be sure before you start gluing. if you use the gray electrical pvc conduit its even cheaper then the white pvc pipe. its like an erector set, all you need is a bunch of tees and short lengths of pipe to connect them and play around with it until you are happy.
    use 1 1/2" pipe like this: http://www.homedepot.com/p/JM-eagle-1-1-2-in-x-10-ft-PVC-Schedule-40-Conduit-67488/100140678
    use these tees: http://www.homedepot.com/p/Charlotte-Pipe-1-1-2-in-PVC-Sch-40-S-x-S-x-S-Tee-PVC024001400HD/203812203
    DO NOT use these, they are weak because not much pipe goes in the fitting and they will break on you: http://www.homedepot.com/p/NIBCO-1-1-2-in-PVC-DWV-All-Hub-Sanitary-Tee-C4811HD112/100344315
    these are the best clamps to use: http://www.homedepot.com/p/Raco-EMT-1-1-2-in-2-Hole-Steel-Strap-2-Pack-2096B2/203671472
  6. Jul 29, 2015 at 10:38 AM
    keakar
    karl
    louisiana
  7. Mar 8, 2016 at 4:14 PM
    miles3774
    miles3774 Active Member
    Miles
    1999 Toyota tacoma
  8. Mar 8, 2016 at 5:53 PM
    00yotasr5
    00yotasr5 Well-Known Member
    lee
    merced, ca
    00 SR5 4X4 RED DEVIL
    Icon ext travel expo leafs rear billies 5125 10'' travel bamf bpv relocate Brute Force Fab Sliders allpro ss brake lines f/r LR UCA 22in wetokled bar RAT Products ifs skid ARB rear locker Ultra gauge Redline Hood Struts Blue Sea Fuse box smittybilt xrc 9.5 w/TJM synthetic rope trail-gear rock assault low profile bumper LED bed strip 12v/usb charger in truck bed
    BookieBob and miles3774[QUOTED] like this.
  9. Mar 10, 2016 at 12:35 PM
    bluezzy
    bluezzy Love My SuperCharged 07 Sport!
    Monty
    Eugene, Oregon
    as for me, I think I'm going to go with a telescoping fishing rod.
    miles3774 likes this.
