need info about lifts and tires
Discussion in 'Suspension' started by arty0811, Feb 22, 2011.
  1. Feb 22, 2011 at 8:49 AM
    arty0811
    arty0811 [OP] Member
    appomattox, va
    08 tacoma trd
    I have a 2008 tacoma 4x4 access cab. I want to put a lift and mud tires on it for hunting season. I know nothing about it. I want something that still provides a good ride and looks good! If anybody has info for me, please help me out!!
  2. Feb 22, 2011 at 8:52 AM
    bridgcat
    bridgcat Well-Known Member
    Alabama
    Mag Grey 4x4 SR5 TRD Offroad
    Avid Off-road Light bar w/ Line-X, American Aluminum Black LP Toolbox, N Fab black step bars,In-Channel Vent Visors, two 10" Rockford subs, Pioneer Double Din DVD player w/ Metra dash kit, 285/65R18 Nitto Trail Grappler MT/s. 18x9" Black XD Monsters. Weathertech digital fit floor mats. Color matched grille with FJ Tacoma badge. De-badged with black, "4x4" badge on tail gate. Mud flap delete mod. Custon TRD decal, color matched rear bumper, Icon extended travel reservoir coilovers, Icon rear reservoir shocks, Dakar rear leaf pack, extended stainless steel brake lines, Camburg uniball upper control arms, timeren bump stops,Beefed Taco carrier bearing drop, Rockford Fosgate Door speakers, Dynomat doors and rear panel, All pro front bumper.
    The OME setup would probably work great for you. Alot of TW guys run it and love it. Get that and some light racing UCA's and you should be good. You can fit 285's with the OME and might have to do a little bit of trimming but not much. Just my 2 cents. As for tires...everyone is different but I love the cooper stt's. Thats what Im running and love them!
  3. Feb 22, 2011 at 8:55 AM
    mfrantz24
    mfrantz24 Scorched Earth
    CT
    2011 DC LB Sport
    Bilstein 5100's all around (fronts at 1.75")
    how much lift you are looking for might depend on the size tire you want to run, or vice versa.. if you have an idea of 1", 2", 3", etc then you can pick an appropriate tire. if you want a large tire, then you will probably need atleast 3" of lift.
  4. Feb 22, 2011 at 10:17 AM
    arty0811
    appomattox, va
    08 tacoma trd
    well we hunt some pretty rough areas so I would guess at least a 3in lift. So what size tires would I be able to fit that wont rub? And any suggestions on what brand of lift to get that rides good and wont break the bank?
  5. Feb 22, 2011 at 10:26 AM
    BrettBretterson
    BrettBretterson Wild Ginger
    Bothell, WA
    06 DCSB TRD OR 4x4
    5100's
    There are SO many options and variables, you really need to do some of your own research. You should start here: http://www.tacomaworld.com/forum/suspension/11282-tacoma-lift-faq-guide-read.html
  6. Feb 22, 2011 at 10:26 AM
    wolfdog2314
    wolfdog2314 Well-Known Member
    Brush Prairie
    2011 Tacoma 4x4 Sport
    Eibach coils. 5100's all around. AAL. WickedFlow
    3inch lift with tires that won't rub at all without having to trim? 265/75/16.
    If you get new wheels with a back spacing of 4.5 or less you can do a 285/75/16.
    But if u want to go the 285 route you'll most likely have to trim something somewhere.
    Goof lifts are Bilstein 5100's (alone or paired with eibach coils) OME lifts. If u want to spend more search around for new coilover setups out there.
    Go to the toyteclifts.com site and look. Most everything there is good as long as you stay away from spacer lifts.
    Also 3 inches is as high as you'll be able to go unless you get a drop bracket lift.
  7. Feb 22, 2011 at 11:21 AM
    arty0811
    appomattox, va
    08 tacoma trd
    Thanks Brett, that link helped understand a lot!!!!
  8. Feb 22, 2011 at 12:21 PM
    BrettBretterson
    Bothell, WA
    06 DCSB TRD OR 4x4
    5100's
  9. Apr 10, 2014 at 8:53 AM
    Pogram
    Pogram May the force be with you fellow yotas!!
    Boulder CO
    Toyota Tacoma Sport 4x4
    Side Steps....For now.
