need info help 18x9.5 -12
Discussion in 'Wheels & Tires' started by Biggi_e, Aug 30, 2016.
  1. Aug 30, 2016 at 7:19 PM
    Biggi_e
    Biggi_e [OP] Well-Known Member
    PA/MD
    2015 Black Tacoma TRD Sport
    so im receiving a 3in spacer lift and soon to get 18x9.5 -12 offset wheels. what size tires will i need to run? what kind of trimming will be needed? pics would help also.
    Thanks!
  2. Aug 31, 2016 at 1:35 PM
    Biggi_e
    PA/MD
    no one??
  3. Aug 31, 2016 at 1:42 PM
    eccracer104
    eccracer104 O.G. Member
    San Diego, CA
    2016 Tundra 4x4
    What size do you want to run? There's no "required" size, you just need a tire that will mount on your rim. While shopping for tires you will see a spec that says rim width range make sure the tire will mount to your width and that it's for the correct diameter wheel. From there the larger tire you go with the more trimming that's required.
    Fender trimming isn't the same for everyone. Two people with the same truck, same suspension, same wheels and tires may need to trim differently. Only way to know is when you get it all installed. Typically its the lower front of the plastic fender liner, and the lower back of the fender liner. You may also need to do the cab mount chop to alleviate rubbing.
  4. Aug 31, 2016 at 1:45 PM
    Biggi_e
    PA/MD
    i dont want anything too big of a tire but not too small where it looks like my truck skipped leg day. i do a lot of driving, 32k in 1 year.
  5. Aug 31, 2016 at 2:25 PM
    eccracer104
    San Diego, CA
    2016 Tundra 4x4
  6. Aug 31, 2016 at 2:27 PM
    Biggi_e
    PA/MD
    Awesome! Ive tried searching but never got any good info. Maybe i was being too specific.
    Thanks for the help!
  7. Aug 31, 2016 at 2:28 PM
    eccracer104
    San Diego, CA
    2016 Tundra 4x4
    Honestly I struggle using the search tool on TW, I use google and search tacomworld blah blah blah whatever I'm searching and it's much more useful.
    Biggi_e[OP] likes this.
