Need info on a tool box
Discussion in '2nd Gen. Tacomas (2005-2015)' started by blakecollins2010, Oct 3, 2014.
  1. Oct 3, 2014 at 7:01 AM
    blakecollins2010
    blakecollins2010 [OP] Member
    Blake
    florence sc
    2010 tacoma sport double cab
    I have a 2010 Tacoma sport with a short bed. every tool box that I've found is 60 inches for a small truck. well that's way to narrow for my truck. I would like for it to go from side to side which is about 65 inches. I want to put bed rails from the rear to look like their going into the tool box but I cant because of the narrow box. should I try a tundra box? or t-100?:confused::confused::confused::confused:
  2. Oct 3, 2014 at 7:04 AM
    blakecollins2010
    Blake
    florence sc
    here's pictures of the previous tool boxes. please help! :mad::mad::mad:
  3. Oct 3, 2014 at 7:05 AM
    mromeo
    mromeo Well-Known Member
    Atlanta GA
    2016 DCSB TRD OR
    None yet
    If you check out my build thread, Ive got a box that goes further onto the rails
  4. Oct 3, 2014 at 7:14 AM
    sr5vic
    sr5vic Buy & Hodl
    British Columbia
    '13 Access Cab SR5 4x4
    295/70/17 Geolander G003 M/T's, 17" Work S1HC's, 1" Bora Wheel Spacers, King 2.5 EXT Coilovers, King 2.5 Tundra Rears, Total Chaos UCA's, Total Chaos LCA's, BruteForce Fab Rear Bumper w/ Tire Carrier, OME Dakar CS047R Leaf Springs w/ D29XL AAL, 'OCTACO' Custom SS Brake Lines, Extended R.Diff Breather, RDI Aluminum Skid Plates, BAJADESIGNS Squadron Sport LED Yellow Fog Lights, BAJADESIGNS Squadron Sport LED Clear Front Spot Lights & Rear Work Lights TRD PRO Grill, TRD PRO Headlights, US Offroad Winch Mount, SmittyBilt X2O 10k Winch, RotoPax 2Gal. Fuel & Water Canisters , VIAIR Constant Duty OBA System, Custom Bussmann RTMR Panel, Total Chaos Bed Stiffeners, StopTech Slotted Rotors, TRD Brake Pads, Off-Grid Engineering Dual Battery System w/ Blue Sea 7622 ML-ACR 500 Relay, Dometic CFX40 w/ slide
    Look at UWS. they make some at 63 for our trucks.
  5. Oct 3, 2014 at 7:25 AM
    blakecollins2010
    Blake
    florence sc
    would a tundra, t-100, or a t-150 fit? its easier to find their tool boxes because I don't want to spend close to $400 on a tool box
  6. Oct 3, 2014 at 7:51 AM
    mromeo
    Atlanta GA
    2016 DCSB TRD OR
    None yet
    I got mine from Lowes for like $150
  7. Oct 3, 2014 at 8:30 AM
    boomer6
    boomer6 Well-Known Member
    TN
    Tacoma TRD Offroad
    disabled DRLs disabled seat belt chime disabled the key in the ignition with door open buzzer Installed Illuminated 4wd switch circuit board Marker lights Flashing with turn signals Toggle switch ABS Disable Fog Lights on AnyTime Mod Changed to Yellow bulbs in the Fog Lights Converted interior lights to leds Installed oem roof rack Installed Firestone Ride Rite Air Bags and Daystar Cradles for the air bags Added oil catch can Relentless Tailgate Protector installed
