Need info on gear swap for 32's
Discussion in '2nd Gen. Tacomas (2005-2015)' started by airplanebuilder, Jan 27, 2019.
  1. Jan 27, 2019 at 7:39 PM
    airplanebuilder
    airplanebuilder [OP] Well-Known Member
    2013 Tacoma TRD Sport
    I have a 2013 TRD Sport with an automatic and 265/70/17's (31.6"). I always thought the 3.73 factory gearing is too tall, even with stock tires. Now that I've gone up an inch, it is even worse. My gearing guy says it's not worth the cost to step up to 4.10, and the next step is 4.56. 4.56 is too low, I think, and a 4.30 requires changing the front carrier to accommodate the "thin ring" and pinion. I heard 3rd generation manual transmission trucks have 4.30 gears, which seems like a perfect ratio. Does anyone know if this is a direct front differential (clamshell?) swap? Rear diff 4.30 is available for 8.4 rear, I believe.
    I don't intend to increase tire size, and it doesn't see any serious off-roading. Just looking for a noticeable increase in acceleration without dropping the big bucks on a supercharger.
    AntFo likes this.
  2. May 6, 2021 at 6:36 PM
    AntFo
    AntFo New Member
    Anthony
    Black 2007 2.7l Tacoma Base Access Cab 5spd
    Current: Silver Sky Metallic 2017 3.5l v6 SR5 Double Cab 6spd auto
    I’m looking for the same thing I would like some recommendations. 2017 v6 auto. 265/75/16 I think with some gears and a pedal commander it will be good.
  3. May 6, 2021 at 6:53 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    You will get the thin cut gears and new carrier provided by a reputable company that does a core charge. The carrier break shouldn’t be a reason not to get that ratio.
  4. May 7, 2021 at 10:18 AM
    TimberTiger
    TimberTiger Get Western! ... ig @tcave87
    Tanner
    Arlington, Wa
    2014 DCSB Trd off road , 2002 Ext Cab Trd
    2014 DCSB: nitro 4.30 gears, Eaton/Harrop front locker, Bilstein 6112's w/ 650#, Camburg ball joint UCA's, Marlin cam tab gussets, Wheelers superbumps, Deaver U402 stage 2 leaves, bilstein b110's, u bolt flip, Archive hammer hangers, ADV weld co hybrid sliders, ADV weld co bed rack or Leer 180 w/ windoors, full RCI skids, SCS stealth 6, 35x10.5 kenda RT, ATH fab HC rear bumper, US offroad stealth front winch bumper, Smittybuilt x20 10k winch, ARB simpson III rtt, plenty of dents and scratches Now Sold 2002 TRD ext cab: 06 TRD Tundra coils, tundra 5100s, wheelers HD 3 leaf AAL, rear 5100s, ARB front bumper, SkidRow front skid, Leer commercial cap with windoors, 285/75r16 Kelly Safari TSR
    I have 4.30 nitro gears in my factory front diff
  5. May 7, 2021 at 10:21 AM
    cementnotgray
    cementnotgray Well-Known Member
    Denver, Colorado
    2019 TRD OR M/T
    35s, 5.29s, OVT
    OVTuning is a good compromise if you don't want to pay for a regear. I wouldnt regear unless you know 100% you arent going to go up to 33/35s in the future because you're gonna want 4.88/5.29 gears in that case and paying for 2 regears would be hell
