Need input with uca’s
Discussion in 'Suspension' started by 88Taco, Oct 13, 2017.
  1. Oct 13, 2017 at 1:13 PM
    88Taco
    88Taco [OP] Well-Known Member
    Michigan
    Black 08 DCSB TRD Off-road.
    Rear diff breather mod. Block heater
    I’ve looked around but can’t seem to find a conclusive answer (yes I used the search function) so I’m hoping someone can help me out. I’m getting ready to upgrade my suspension shortly. I’ll be going for a 3 inch lift with fox coilovers in the front. Planning using icon tubular uca’s. Planning on getting new wheels and tires come spring but I’d like to keep the stock 16in off-road wheels with 265/70R16 for my winter wheels. It seems rubbing is a concern when going for a wider tire. Can anyone tell me conclusively (pics would be great) if I will have rubbing issues with stock wheels and 265/70R16's with the Icon uca? Thanks in advance for the input/help.
    tcjacado likes this.
  2. Oct 13, 2017 at 6:35 PM
    88Taco
    Michigan
    Bump. Hoping for an answer
  3. Oct 14, 2017 at 7:23 PM
    JJ04TACO
    JJ04TACO Well-Known Member
    Jim
    Dallas
    04 White DC/TRD
    Fox 2.5 RR front, 2.0 RR rear from AccuTune Offroad, OME Dakar Leafs, Camburg Uniball UCA's, CBI Offroad Bolt on Sliders w/kickout, Scangauge II Uniden Bearcat 880 w/ 3' Firestick on CBI antenna mount B&M Trans Cooler
    Stock wheels and tires shouldn't be an issue. But going wider you may have an issue depending on tire selection and rim diameter. Try the wheel and tires page, there's going to be a ton of stuff there for ya.
  4. Oct 14, 2017 at 7:30 PM
    tcjacado
    tcjacado Well-Known Member
