Need larger tires but have know idea!
Discussion in 'Wheels & Tires' started by JoseyWales, Mar 16, 2012.
  1. Mar 16, 2012 at 6:17 PM
    JoseyWales
    JoseyWales [OP] New Member
    North Carolina
    4door SR5 TRD Off Road
    K&N cold airintake, Flow Master ex.
    I have an 06 tacoma with no lift. I am looking at a small lift by Truxxx Lift Kits that will give me up to 3". Along with that I am looking for the largest tire that will fit with no rub. I would really like 33" but not sure if that is an option. If it is however. What is the right size when ordering 33"? for example I have now P265 75R16. What will I need to move to, to have 33"?
    If I sound like a complete idiot, it is because my father failed me in the auto mechanic area! Now I am trying to figure it all out on my on, or with your help.
    Josey
  2. Mar 16, 2012 at 6:22 PM
    neontrail
    neontrail ✈ ✈ ✈ ✈ ✈ ✈ ✈
    Idaho
    2004 NISSAN XTERRA XE/SE
    De-badged, Tint 20%, Blue 48 LED dome-light, .......
    welcome to the site..... Got Pics of the 06 ?
  3. Mar 16, 2012 at 6:25 PM
    tacoma16
    tacoma16 Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    Depending on how wide of a 33inch tire you get you will be fine with no rubbing, it also depends if you are running aftermarket rims as well. But a cab mount chop will take a way the rubbing
  4. Mar 16, 2012 at 6:26 PM
    JoseyWales
    North Carolina
    Nothing fancy, just a new grill. But I will put some up. I like The full look. ie: slightly lifted with tires that fill out the whole tire well.
  5. Mar 16, 2012 at 6:29 PM
    JoseyWales
    North Carolina
    #3tacoma16[​IMG]
    Senior Member
    Gender: Male
    Double cab SR5 4x42010 Double Cab Automatic V6
    Weather tec floor mats, avid light bar line xed, 2 hella 500ff with a 55w 6000 hid conversion, back up lights, rear view camera on anytime mod, wet okoles, extra d-rings, hi lift mount, illuminated 4x4 switch, relocated rear differential, aux fuse box,
    Ok, i want to go with the widest tire i can. what would you suggest?
  6. Mar 16, 2012 at 6:30 PM
    JoseyWales
    North Carolina
  7. Mar 16, 2012 at 7:12 PM
    Gabe911
    Gabe911 Well-Known Member
    FLORIDA
    10 PreRunner MGM
    Debadged, Rear TSB, Blue LED dome and Bright White Map Lights, Hard Top Tonneau Cover, OME885 coils (no top plate spacers)OME shocks and struts, 1.5" AAL for TSB Rear,285/70/17 Trail Grapplers, 17x9 XD Addicts with 4.5 bs, Black 4" exhaust tip, Bed pocket lights, rear diff breather Mod
    To get a 33" tire if sticking with a 16" wheel...you would order 285/75/16...if going with 17" most come in 285/70/17
  8. Mar 16, 2012 at 7:57 PM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    well in ur post you said you dont want to rub so you would have to go with a 255/80/17 (16 inch rim wuld be 255/85/16) if you want to keep your stock rims. If you dont mind cutting shit up go with the 285 as suggested earlier and get new rims.
