Need leveling kit advice
Discussion in 'New Members' started by Montanafreak, Mar 13, 2018.
  1. Mar 13, 2018 at 10:42 AM
    Montanafreak
    Montanafreak [OP] Member
    Derby
    Havre MT
    2017 Tacoma TRD Off Road DBL Cab
    Diamondback HD cover Diamondback Headache rack Diamondback ATV extension bars Wet Okele Neoprene seat covers 10 ply Hankook tires Fox 2.5 suspension 2021 TRD pro skid plate Rough Country MOLLE rack Full Bed
    I am leasing (try it before you buy it) a 2017 TRDOR 4dr Tacoma. This site did right previously and had me get a Diamondback HD cover. Now I would like to run some Toyo tires instead of the stock Kevlar (which have had 2 flats already) I am being told I need a leveling kit for the front. Which is the right one to buy. I DO NOT want a lift for the whole truck, just a leveling kit on the front. I welcome any and all advice on the subject. I checked with Toyota and it will NOT affect my ability to turn it in at the end. I may keep it, I may buy a 2020 who knows but I love it so far.
  2. Mar 13, 2018 at 3:10 PM
    irayfz6
    irayfz6 TTC #0249
    Joey
    McAlester, OK
    2014 Black SR5 4x4 Access Cab
    What size tire are you wanting to run? You can easily upgrade tires without any lift/level.
    If you do level it, the recommendation around TacomaWorld is usually Bilstein 5100’s with lift coils, and avoid spacer lifts.
    5100’s:
    https://www.headstrongoffroad.com/s...air)_-_24-263108_for_2016__Toyota_Tacoma.html
    You can use your stock coils with these as they are adjustable, or you can add lift coils and set them at the lowest level. This way the coil will provide the lift.
    Lift coils:
    https://www.headstrongoffroad.com/s...-__Various_Lift_Heights_Available_(PAIR).html
    boogie3478 likes this.
  3. Mar 13, 2018 at 3:13 PM
    Heffery5000
    Heffery5000 Well-Known Member
    Jeff
    Haverhill, MA
    2014 tacoma trd offroad access cab blue ribbon metallic
    Urd short shifter Changed out grill Method wheels
    I have toyo open country at2 in 265/75/16 on stock suspension and and stocks wheels have no problems at all. They only rub when i put on a set of spacers i was given
  4. Mar 13, 2018 at 4:15 PM
    Canadianguy91
    Canadianguy91 Well-Known Member
    Sean
    Halton Hills, Ontario, Canada
    2016 Limited
    Krown undercoating, Protect a plate, blindspot mirrors, Reese stainless steel towing ball, Bakflip MX4 tonneau cover, Tufskinz tailgate letter inserts, Console organiser, Tinted windows, LED interiors, Bed lights, Hood lights, Black Canadian flag decal (@bfeth), Oem bed mat, WeatherTech floor liners, Arctic Claw XSI tires, Recovery Shackle, Ultimate LED turn signals V3 @mesojdm, OEM TRD Off-Road tow hook, Bilstein 5100's with ARB's Old Man Emu 2887 coils, ICON progressive add a leaf, General Grabber ATX tires, Fuel ripper rims, Auxbeam F-16 H11 Led headlights, Borla S-type catback exhaust with black tip, custom powertray, vinyl badge inlays, (@rrentrop), Rear diff breather mod, Redarc trailer break controller https://m.youtube.com/watch?v=qqN7m1pc6AA
    is there a benefit of using lift coils? Cause don't the Bilstein's give you the lift anyways?
  5. Mar 13, 2018 at 4:20 PM
    Heffery5000
    Jeff
    Haverhill, MA
    I could be wrong but i believe with the 5100 set at 0 you get a stock height and then preload the spring more to get some lift thus thus stiffening the ride to a degree. Lift coils will give you some lift without adding extra preload which to some peoplea opinions makes it ride nicer while still adding lift. Dont quote me im newish here and have bone stock suspension
    irayfz6 likes this.
  6. Mar 13, 2018 at 4:21 PM
    Canadianguy91
    Sean
    2016 Limited
    how about if you set it to the highest setting?
  7. Mar 13, 2018 at 4:23 PM
    Heffery5000
    Jeff
    Haverhill, MA
    I dont know enough about them to say how much lift youd gain at max setting with stock or aftermarket coils
  8. Mar 13, 2018 at 4:51 PM
    irayfz6
    irayfz6 TTC #0249
    Joey
    McAlester, OK
    ^correct.
    Edit: I just realized I literally quoted you even though you said not to.
  9. Mar 13, 2018 at 4:52 PM
    Heffery5000
    Jeff
    Haverhill, MA
    Sweet i didnt make an ass of myself thanks for the confirmation
    irayfz6[QUOTED] likes this.
  10. Mar 14, 2018 at 6:03 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Welcome to TW!
  11. Mar 14, 2018 at 6:13 AM
    Clearwater Bill
    Billy
    Largo Florida
    By whom?
    For what size replacement tire? You can run full 33" if you pick the right tire and wheel combo, no lifting, no rubbing. A few threads around on that.
    Of course. You can also turn it in with a dented fender or excess mileage. But that doesn't mean they won't ding you on your residual value.
    Just because someone 'says' that is meaningless. Get it in writing. If they won't do that, be prepared to remove whatever you put on. Just in case.
  12. Mar 14, 2018 at 6:15 AM
    Steviepb5
    Steviepb5 Well-Known Member
    2014 Tacoma TRD Sport
    Headlight blackout
  13. Mar 14, 2018 at 8:01 AM
    ODNAREM
    Ron
    Huntington Beach,CA.
    2012 TRD Sport Prerunner
  14. Mar 14, 2018 at 4:32 PM
    Tonytrd2144
    Tonytrd2144 Well-Known Member
    Tony
    Indiana
    2023 Tacoma Limited
    2 inch ready lift KO2
    BDS leveling kit is what I have, raised the front about 2 1/2” and 1” in th rear, added the Fox 2.0 shocks on the rear also. Total for kit and shocks was $450
