Need longer shocks for the front
Discussion in 'Suspension' started by x2Kawa, Jun 9, 2011.
  1. Jun 9, 2011 at 4:40 PM
    x2Kawa
    x2Kawa [OP] Member
    Taylor
    Houston, TX
    Hey guys here's my situation. I bought the ToyTec 3'' lift with OME front coils and now my stock shocks for the front are way to short and can't extend all the way when I hit a bump or something. So I was wondering if anyone knows of a front shock with 2.5in extra travel? The Bilstein 5100s for the taco don't give any extra travel so those won't work. 2007 Tacoma Doublecab 2wd
  2. Jun 9, 2011 at 4:43 PM
    PreRunnerSeth
    PreRunnerSeth Well-Known Member
    Apex, NC
    16 Super White Limited 4x4
    Just get the OME shocks are made to work with their coils.
  3. Jun 9, 2011 at 4:51 PM
    x2Kawa
    x2Kawa [OP] Member
    Taylor
    Houston, TX
    Ya I would think that would work but ToyTec also seems to think the Eibach/Toytec front coil springs work with the 5100s and that can't be true at least not for full downward travel. Does anyone know the actual specs for the OME shocks?
  4. Jun 9, 2011 at 4:55 PM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    get limit straps? :notsure:
  5. Jun 9, 2011 at 5:19 PM
    x2Kawa
    x2Kawa [OP] Member
    Taylor
    Houston, TX
    I just got off the phone with OME and the specs for the shock for their coil is the same travel as the stock strut
  6. Jun 9, 2011 at 5:23 PM
    TheHansen
    TheHansen Well-Known Member
    Mattapoisett, MA
    05 DC Sport
    dtrl mod Fog light mod Bed lights Under hood lights Rear window decals tint matched front windows Rear dif breather mod weathertech floor mats Bed mat Scan gauge 5100's and 885's lean spacer 1.5 in aal, 1" block and OME rear shocks Dynomax muffler (weld in) Truxedo lo pro qt bed cover Devil horn Emblem Plasti dip badges plasti dip radio plasti dip ac control all pro rear bumper with side pieces All pro front bumper All pro bolt on sliders illuminated 4x4 switch JBA long tube headers URD o2 Sim
    when you lift you lose downtravel... unless you go long travel there isnt really much else you can do
    Some say uni-ball upper control arms will give you more droop though. I don't know first hand but i have read that.
  7. Jun 9, 2011 at 5:23 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    With the stock shock, a 3" lift coil will take almost all the droop travel out of the front suspension. If you want more, you'll need extended travel coilovers and upper control arms.
  8. Jun 9, 2011 at 5:27 PM
    x2Kawa
    x2Kawa [OP] Member
    Taylor
    Houston, TX
    What would be a good extended travel strut?
  9. Jun 9, 2011 at 5:30 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Yeah, what they all said.
    If you have NO downtravel at all, I'm guessing you didn't use the 0" spring perch setting on the 5100s, or otherwise brodied up the strut assembly or installation.
    But if you measured out at 3" of lift then yeah, you're just seeing downtravel loss.
    I found I got a little droop back by going LR UCAs. Still nothing like stock downtravel, though.
  10. Jun 9, 2011 at 5:31 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    How are you determining full downward travel? And that your shocks are too short?
    If the shocks were much longer, the suspension would be able to travel too far, max out the ball-joints and CVs. Which would then lead to premature failure of the parts. Similar to an All Top-Spacer Lift.
  11. Jun 10, 2011 at 12:50 PM
    x2Kawa
    x2Kawa [OP] Member
    Taylor
    Houston, TX
    I do still have some downward travel just I wish I had more because if i hit a speed bump or a bump to fast you can feel the front extend all the way and jolt the truck which to me a lifted truck should have great travel down and up. But after looking last night and taking the strut out and then pushing the lower control arm down I see that it maxes out about the same length as the strut.
    It might just be a side-effect of a truck and if so then i'll get over it.
