Need lower profile lca bumps suggestion?
Discussion in 'Street Trucks' started by Az lowtacoma, Oct 16, 2012.
  1. Oct 16, 2012 at 10:39 PM
    Az lowtacoma
    Az lowtacoma [OP] Well-Known Member
    Seth
    Arizona
    I was examining my front suspension the other day after after lowering the rear a little more and i noticed i don't have shit for travel before it smashes the bumps. What specific preferably Engery Suspension bump stop works with for repalcing the front bumps?
  2. Oct 16, 2012 at 10:55 PM
    Beefed Taco
    Beefed Taco Taco Vending Machine
    Brian
    My Metal Shop
    99 Taco
    streetacos.com parts!
    There are a couple choices you can use...it sounds like you have cut coils or drop coils that have had a coil or so removed? You can use this button style Energy bump stop, but they may be too low profile and let your tire scrub the inner fender too much, or you could also try these pyramid style I run on my 99 and they'll be bit lower profile than your stock rubber ones but the poly will slow the tire better than the soft stock rubber ones.
  3. Oct 16, 2012 at 11:15 PM
    Az lowtacoma
    Seth
    Arizona
    I have the Belltech drop coils. Awesome thaks Brian!! What all do I need to do to remove the stock bumps since it's a pretty tight gap in there to get them out?
  4. Oct 16, 2012 at 11:24 PM
    Beefed Taco
    Brian
    My Metal Shop
    99 Taco
    Jack your truck up by either the cross member behind the sway bar to get a bit more room so you can remove the stock ones or jack it up under the drivers door by the frame, but you'll have to do one at a time this way. It's a 14mm or 9/16" socket that you'll use up through the bottom of the lower arm. Do you need the part #'s for these 2 style bumps?
    I have the button ones here but will need to order the pyramid ones from my u-bolt/spring guy but he gets them quick. They run me like $11 and I sell them for $15+ shipping, so about $20 when it's said and done. ORW or 4WP usually has the button style on the shelf for about $11 or so but they'll probably have to special order the other ones since they're not that common.
  5. Oct 16, 2012 at 11:31 PM
    Az lowtacoma
    Seth
    Arizona
    Ok that was what I figured ha. Part numbers would be awesome. Well I would rather run the pyramid ones since they sound like the safer opition since I will be running 17s here soon
  6. Oct 17, 2012 at 12:35 AM
    Beefed Taco
    Brian
    My Metal Shop
    99 Taco
    Thanks Seth. I was doing some computer crap a minute ago and kind of left you hanging. I have to make a u-bolt run in the next 1-2 days and will get these and get 'em in the mail. There won't be a long wait. These should work great with the drop and 225/45/17's.
  7. Oct 17, 2012 at 7:46 AM
    Az lowtacoma
    Seth
    Arizona
    Awesome thanks again for the help Brian much appriciated
