need more info !
Discussion in 'Suspension' started by Randy Y, Dec 24, 2010.
  1. Dec 24, 2010 at 11:05 AM
    Randy Y
    Randy Y [OP] Active Member
    2010 4x4,4 cyl. 5 speed
    I have a 2010 reg. cab 4x4, i have purchased 3" spacers for front and 1" blocks for rear but have not installed. I see alot of comments on bilstein 5100 's, what is the difference in these to obtain lift / level ? I dont want to install anything that is going to cause problems later so do I need to reconsider the spacer/block setup? A little info on how the shock set up works would be appreciated, or pros/cons. thanks for your time !
  2. Dec 24, 2010 at 11:11 AM
    Hunter500ky
    Hunter500ky Well-Known Member
    E-Town Ky
    06 Tacoma 4x4 SR5
    Weathertech Mats, Toolbox, 6k HID fogs, Hardwire Escort 8500 x50,
  3. Dec 24, 2010 at 11:12 AM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    not to be a dick or nothing but use the search option.just spend some time reading and im sure you will find your answers.this topic has been:deadhorse:.
  4. Dec 24, 2010 at 5:40 PM
    Randy Y
    wow, thanks
