Need more leg room!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Lee, Mar 23, 2014.
  1. Mar 23, 2014 at 8:38 PM
    Lee
    Lee [OP] leea1983
    Lee
    Arizona
    07 SR5 4 door Tacoma
    I have a 2007 Double Cab. My son is 6' 3" and needs more leg room. Does anyone know if there is any way to extend/make the drivers seat move back a few more inches?
  2. Mar 23, 2014 at 8:39 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    He needs more leg room or the steering wheel sits to low?
    I'm about 6'3'' and i have no issues with driving a 2nd gen tacoma except the rearview mirror is really low, and the steering wheel is to low.
  3. Mar 23, 2014 at 8:45 PM
    Lee
    Lee [OP] leea1983
    Lee
    Arizona
    He needs the seat to go back more. The steering wheel position is fine.
  4. Mar 23, 2014 at 8:48 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Really..... Tell him not to drive like a gangster and he'll have planty of room.
  5. Mar 23, 2014 at 8:49 PM
    95 taco
    95 taco Battle Born
    Hmmm, the only way i see is to fab something that extends all the mount points back, but i think that would raise the seat up.
  6. Mar 23, 2014 at 8:52 PM
    Lee
    Lee [OP] leea1983
    Lee
    Arizona
    He has tried the gangster position, doesn't work for him. I've searched the net and can't find anything for it.
  7. Mar 23, 2014 at 8:55 PM
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    Chop the seat frame track, weld in a spacer and in the rear you will have to bend cut weld and drill the rear mounts
  8. Mar 23, 2014 at 9:05 PM
    Sbasser
    Sbasser Active Member
    Renton Washington
    TRD Off Road 4x4
    Trailer pkg. 6 spd.
    Well, I'd tell him to get his own truck! Seriously, I'm 6' 2"+ and on my Access Cab, can push the seat back enough to where I can't push the clutch down far enough to start the engine. Luckily, it's a 4x4 and has the "Clutch Start" button, which I almost always use anyway. I wear 35" sleeve dress shirts (well, at least that's what fits) and could really use the steering wheel to telescope closer to me. It's not perfect, but I've done 18 hour days in the driver's seat...can't be all that bad.
  9. Mar 23, 2014 at 9:06 PM
    1of7627
    1of7627 Well-Known Member
    Mark
    Post Falls, ID
    '14 DCLB Ltd, '63 Corvair Spyder
    Things I need to tow.
    Geez, I'm 6'4" and I can move the seat back too far.
  10. Mar 23, 2014 at 9:12 PM
    sr5vic
    sr5vic Buy & Hodl
    British Columbia
    '13 Access Cab SR5 4x4
    295/70/17 Geolander G003 M/T's, 17" Work S1HC's, 1" Bora Wheel Spacers, King 2.5 EXT Coilovers, King 2.5 Tundra Rears, Total Chaos UCA's, Total Chaos LCA's, BruteForce Fab Rear Bumper w/ Tire Carrier, OME Dakar CS047R Leaf Springs w/ D29XL AAL, 'OCTACO' Custom SS Brake Lines, Extended R.Diff Breather, RDI Aluminum Skid Plates, BAJADESIGNS Squadron Sport LED Yellow Fog Lights, BAJADESIGNS Squadron Sport LED Clear Front Spot Lights & Rear Work Lights TRD PRO Grill, TRD PRO Headlights, US Offroad Winch Mount, SmittyBilt X2O 10k Winch, RotoPax 2Gal. Fuel & Water Canisters , VIAIR Constant Duty OBA System, Custom Bussmann RTMR Panel, Total Chaos Bed Stiffeners, StopTech Slotted Rotors, TRD Brake Pads, Off-Grid Engineering Dual Battery System w/ Blue Sea 7622 ML-ACR 500 Relay, Dometic CFX40 w/ slide
    im 6'3" and have more than enough room. maybe hes all legs? lol
  11. Mar 23, 2014 at 9:29 PM
    TacoBrah
    TacoBrah Well-Known Member
    Sean
    Icon stage 1, 255/85/16 KM2
    Tell him to man up. Im 6'5" and have zero problems with leg room.
  12. Mar 23, 2014 at 9:53 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    +1, and I've got a regular cab.
  13. Mar 23, 2014 at 10:05 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    My buddy is 6' 5" and drives a 2007 access cab and has no issues. :notsure:
  14. Mar 23, 2014 at 10:13 PM
    TallGuy24
    TallGuy24 Member
    Jonathan
    Columbus, Ga.
    08 PreRunner TRD OR DCSB
    I'm 6'6, and this is the first vehicle I've ever driven that I haven't needed the driver's seat allllllllll the way back.
  15. Mar 23, 2014 at 10:35 PM
    Joe D
    Joe D .
    Tell him I'm 5-9 & 175 and I fit...
    If he's not fitting he's not fitting. You'll need to modify the seat rails. Good luck.
  16. Mar 23, 2014 at 10:50 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    And the final word is:
    Your son is just being hard to please. Tell him to man up until he can afford to purchase his own ride.
  17. Mar 23, 2014 at 10:57 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    This.
    If I move the seat all the way back I have diffaculty driving the truck safely. Im 6'1.
  18. Mar 23, 2014 at 11:00 PM
    TCprerunner
    TCprerunner Well-Known Member
    6'3 and have no issues other then I can't stretch out
  19. Mar 23, 2014 at 11:02 PM
    inesshell
    inesshell blah blah blah
    All stock Superwhite 10' AC
    LOL :amen:
  20. Mar 24, 2014 at 5:23 AM
    ozmon420
    ozmon420 Well-Known Member
    miami, florida
    08 tacoma
    18x9 pro comp 7031 rims, alpine iva-d310 w/sirius sat radio, ipod connection, tv tuner, reverse camera, bug deflector, wet okole seat covers, tinted windows, running boards, toytec coilovers front set at 2.5'' , AAL rear,5100's rear, TC UCA, leer topper, bruteforce rear bumper, ARB rear locker.
    damn, you must be pretty crammed in there.
