need more lift add to coil spacer lift
Discussion in 'Suspension' started by bigcuzauto, Oct 15, 2010.
  1. Oct 15, 2010 at 8:23 PM
    bigcuzauto
    bigcuzauto [OP] Active Member
    Louisiana
    2006 tacoma trd
    3 in coil spacer lift 285/75/16 buckshots dent in the rear
    I have an 06 trd off road with a 3 inch revtech coil spacer kit. I want more lift. Should I go body or is there another way to add to what I have?
  2. Oct 15, 2010 at 8:25 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    its either body or 6 inch lift
  3. Oct 15, 2010 at 8:27 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    this guy knows his shit. no more lift after the 3 inch unless you go drop bracket or body lift
  4. Oct 15, 2010 at 8:38 PM
    bigcuzauto
    Louisiana
    2006 tacoma trd
    thats what I was afraid of I am used to straight front axles just add more springs and up you go thanks
  5. Oct 15, 2010 at 8:39 PM
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    Just do a SAC.
  6. Oct 15, 2010 at 9:05 PM
    bigcuzauto
    Louisiana
    2006 tacoma trd
    got a 77 bronco for the bad shit taco is daily driver
  7. Oct 15, 2010 at 9:24 PM
    ktmrider
    Junk
    I dont think the body lift would effect articulation except for the center of gravity being off:)
  8. Oct 15, 2010 at 9:30 PM
    mnudo200827
    mnudo200827 Well-Known Member
    Michael
    Corona, CA
    2005 Tacoma Double Cab Prerunner
    Icon Coilovers, All-Pro UCA's, All Pro 3" Leaf Springs, Rear Fox Adjustable Shocks, Stainless Steel Brake lines, 17" KMC Addicts wrapped in 305/65/17 KM2's, Kenwood DDX 512 stereo, 2 12" Polk Audio MM1240 subs in custom enclosure, 4 component speakers, Wet Okole Seat Covers
    if you dont have 4WD, you can get new spindles from camburg or total choas, with the spacer lift that would give you 6.5"-7" of lift. If thqas too much you could take out the spacer or put a smaller one in. But this is only if you are NOT 4WD. If you are 4WD then drop bracket is the way to go. RCD makes a 4-5" lift and Pro comp and Fabtech make a 6". Body lift is the wrong way to go, there is some pics on here with truck that have been in accident with body lifts and the body almostscames off the frame.
  9. Oct 15, 2010 at 9:36 PM
    tacosupreme54
    tacosupreme54 Well-Known Member
    NW GA
    Off-Road 4x4 SR-5
    OME 885's, 90000 and n182 shocks, CB drop, 295/75/16 Hankook Dynapro MT RT03's, 16"x8" Pro Comp 7089 wheels, Avid Off Road Light Bar, Magnaflow 12226-14'' Muffler dumped after axle, color matched grille, Team Realtree camo seat and steering wheel covers, Husky floor liners, towing hitch, bed extender, Tacoma bed mat, all black emblems, black sockmonkey decals, bedlined rear bumper.
    if you can afford it, go with the RCD lift or spindle lift, depending on if you're 4x4 or not. they're both just right. if 3'' is not enough and 6'' is too much, then the 4"-5" of those two are perfect. i personally think 6'' looks a little dumb on our trucks and there's been a few ppl on here with 6'' lifts that have had rollovers. body lift is also a bad choice.
  10. Oct 15, 2010 at 10:05 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I fully endorse what He said ^^^^
  11. Oct 15, 2010 at 10:08 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Anything wrong with this pic?
  12. Oct 15, 2010 at 10:09 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Ruh Roo Shaggy.....
  13. Oct 15, 2010 at 10:10 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    As you can see, The mounts pushed thru, into the cab
