Need more light, buy new oem or other
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Kotah, Jan 27, 2018.
  1. Jan 27, 2018 at 5:26 AM
    Kotah
    Kotah [OP] Well-Known Member
    TN
    2013 silver trd off-road Dc
    Oem running boards Window vent shades Oem bed mat liner
    My headlights just dont seem bright, the bulbs are going on 5 yrs old now and my eyes dont see as good as they use to. Would new oem bulbs be worth the investment since mine might have lost some of there brightness or do i need to go another route, my main problem is in real dark areas where there is no street lights and wore out divider lines on the highway.
  2. Jan 27, 2018 at 5:31 AM
    Keep on Truckin'
    Keep on Truckin' Well-Known Member
    Jarvis
    Indiana
    02 Imp. Red - Ext. Cab SR5 4x4- 2.7- Auto
    Rear Locker, TRD Alloy Wheels & Cooper AT3 Tires, Camper Shell ,, K&N ,Icon AALS
    Try Sylvania Ultras, Phillips Xtreme or Osram Nightbreakers -OEM style bulbs @ Xenon Depot -
    crashnburn80 likes this.
  3. Jan 27, 2018 at 5:31 AM
    taco2010trd
    taco2010trd Cyber Bully
    Tampa, Florida
    2010 Silver TRD OR DCSB
    I installed osram nightbreaker bulbs and saw a nice improvement
  4. Jan 27, 2018 at 5:34 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    Are your headlight lenses hazed over blocking a lot of the light output?
    You can get some brighter headlights. I think the design of the stock headlight housings kind of suck for getting a good beam area.
    Use your driver's lights at night. It helps get more side light.
  5. Jan 27, 2018 at 5:49 AM
    Kotah
    TN
    My headlight housings are crystal clear, and you are right about running the fog lights for more light, i can actually see the road edges that way but figure they might be to much for on comming traffic as i dont want to blind people
  6. Jan 27, 2018 at 6:10 AM
    Clearwater Bill
    Billy
    Largo Florida
    Look for post 'ultimate headlight upgrade by @crashnburn80
    Do that and enjoy.
    Sidenote, are you dealing with cataracts? Huge improvement to get them gone if so
    crashnburn80 and JGO like this.
  7. Jan 27, 2018 at 6:29 AM
    80schild
    80schild Well-Known Member
    Chad
    Flori-Bama
    2007 TRD Sport Access Cab
    I do get flashed occasionally while using mine.
  8. Jan 27, 2018 at 6:41 AM
    L J
    L J Well-Known Member
    Illinois
    07 4X4 SR5 TRD Sport DCLB
    The brighter bulbs will give better output but be prepared to buy them more often. I was running them but was only getting a year or so before having to buy again. I went back to the OEM Osram bulbs. I don’t think your fog lights are going to blind anyone.
  9. Jan 27, 2018 at 6:51 AM
    Keep on Truckin'
    Jarvis
    Indiana
    I just replaced the Sylvania Ultras yesterday after 5 years , both bulbs burnt out within a day of each other. I went with the Osram Nightbreakers @ Xenon Depot
  10. Jan 27, 2018 at 9:46 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Headlight bulbs dim over time. 5yr old bulbs would be pretty dim. Just going with a quality non-coated bulb replacement would be a big improvement.
    Here is what @Clearwater Bill was referring to:
    https://www.tacomaworld.com/threads/the-ultimate-h4-headlight-upgrade-not-led-or-hid.398066/
    Excellent choice for stock wattage performance. Philips Xtreme is another good one, the latest highest performing versions of each are the +130s.
    Fogs have clean cut low offs, they shouldn’t blind or even annoy any oncoming drivers. If you are getting flashed when running your fogs something is not right in your setup. If you’ve put LEDs in your fogs that would certainly blind people.
    Side note from the side note. I was reading an interesting SAE paper the other day discussing how the lighting changes to short wave length sources is causing significant night time visability issues for those with certain vision deficiencies, one of which is cataracts. And it isn’t just headlights, but also the new high intensity LED street lights can be problematic on wet road surfaces due to refraction.
